mine were pretty noisy for a while...they quieted down after a while but I still hear them.
I thought you fill both cases through the rear case oil fill hole. If I'm mistaken please let me know.
Best you recheck the oil level in the Tcase, you should have put one qt in the crawl box as stated above. Since you did not you should be one qt low, it takes awhile for the oil to get in the crawler. I would fill and recheck a few times after driving to make sure its full.
i'm gonna reckon you didnt dump a quart in the front case eitherthis is why after they ran awhile they quieted down, you were running the front case dry, as you drove oil finally worked its way thru and leveled out, but gear oil is thick , it takes awhile to pass thru the small holes and seep thru the bearings to the front box
Started by TERRIBLEONE Toyota Pickup/4Runner Tech 1979-95
Started by calitaco Toyota Pickup/4Runner Tech 1979-95
Started by partyman66 Engine
Started by fishy97t100 Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by toyodaaddict Newbie Questions
