Frankenstein II - Going on Tons (Updated 2-5-09)
Started by AaronB, May 25, 2008, 08:48:58 PM
AaronB
#60
got the rear axle prepped and ready to tack on the AP spring perches
AaronB
i think im going to paint it the same color as the old rig
joey0712
Dang... already talkin about paint...... I like that color should be sweet!!!!
91 Toyota High pinions f&r.
AaronB
i was just looking over all my old picks and it got me  :think:
paints still a looooong way down the road  :willynilly:.
AaronB
#64
got the rear end set and ready to go, just need to wait until i get the engine in and the bed on so i can get the correct angle for the drive shaft.
The third I thought I jacked up worked perfectly on the rear  :clap2:  So I didnt have to scrap it  :willynilly:
AaronB
#65
starting to look like something  :dunno:
AaronB
#66
my awesome skills at work  :haha: :laugh:
CrazyYota
AaronB
scored at the pick a part today
AaronB
also got the motor mounts in, going to try and mount the motor up tomorrow.
AaronB
#70
question for you tcase gurus. I have these 2 cases and am wanting to make duals. they are different cases but both 21 spline. is it possible to use them with the MC-07 adapter?  :dunno:
just wasnt sure because the case in the top pic has the rails coming out. forward shift?.
CrazyYota
Quote from: Aaronb on October 25, 2008, 03:09:35 PM
the one with the rails is forward shift, you can use that one as the crawl box and bolt the top shift behind it. or go to pick a part and get the shift rails from a topshift to convert your forward shift. and both would be topshift :beerchug:
AaronB
Duffil
The above info is correct as long as you are going to be running a forward shift trans. G52/54-R151F-W56C/D. or, like he said, you will need an extra set of top shift rails.
AaronB
ok so ill be good with running the top shift as the rear case?
unclejpl4x4
just read threw i like so far. sorry 2 hear about the third.  and i think the paint will be bad ass
gotrocks
Cool build so far man.  I don't know if I caught this but what size tires are you going to run?
Quote from: Aaronb on October 26, 2008, 07:54:35 AM
Ya, the rear case has to be a top shift.  like they said, the front can be either one depending on the transmission.
AaronB
Quote from: Hyena on October 26, 2008, 11:27:30 AM
Im going to be running th350 with a AA adapter, so i should be alright with the forward shift as the front case.
AaronB
Quote from: gotrocks on October 26, 2008, 10:13:36 AM
Im going to be running 35 or 36's not sure yet
AaronB
Quote from: Aaronb on October 26, 2008, 11:45:18 AM
one more thing! In order to use the AA adapter I have to remove this clip. Will that be ok? it seems like its just a "backup" bearing retainer.
toy4x4ota
with an adapter from the trans, you will probably need another top shift, or just the shift rails.  the forward shift t-case works with the toyota transmission, i doubt the adapter will allow you to use the forwardshift case.  the bearing retainer should be used but i dont think it will make a big difference, my buddy put together some cases and forgot to put that back and it seemed to be fine. hope that helps
LIFTED TRUCKS ARE GAY
AaronB
#82
the adapter should work fine it actually has an area cut out so you can run a forward shifting case. Ill be allright with the retainer out too, it looks like it was there because on a w56 tranny there is nothing there to hold the lower bearing in place.
toy4x4ota
cool deal, i have never seen one of those adapters
AaronB
Quote from: toy4x4ota on October 26, 2008, 10:08:04 PM
Yeah its from advanced adapters, there like over $500 brand new. I scored this one for $200.
GJToyotabug
oh i like this i cant wait for it to be done
AaronB
#86
Quote from: GJToyotabug on October 27, 2008, 11:42:54 AM
Thanks. I can't wait either, its allready dragging out to long. I just need a few more parts, Then all I have to do is the tubing for the roll cage. I'll give it about 2 more months depending on the weather  :crossed:
AaronB
got the motor set in.
Jud
"bout tree fiddy"
AaronB
