Frankenstein II - Going on Tons (Updated 2-5-09)
Started by AaronB, May 25, 2008, 08:48:58 PM
Duffil
Well in that you don't need the gearing to be as low, yeah. Duals or 4.7s aren't as important.
I remember reading something a while back about inchworm working to fix the problem with fluid draining into the back of the case, but I don't know what ever became of it.
AaronB
so this is what i was thinking about doing to weld up the 3rds. I have seen other people do it this way but have never heard anything on how well it worked. What do you guys think?
mock up cardboard piece
joey0712
That is how i did mine i used a piece of 3/8 i think and welded it hot with 6011 it has been great so far
91 Toyota High pinions f&r.
AaronB
Quote from: joey0712 on September 14, 2008, 09:10:53 PM
welded it hot
not sure what your talking about! Did you heat it up with a torch first?
joey0712
no no i just welded it with the amps up pretty high
AaronB
Duffil
Yeah definitely burn that sucker in. I tried to do mine "clean" with low settings to reduce warpage.  It lasted about 1 burnout and 15 miles before it blew apart. :haha:
joey0712
o ya haha i wasnt shootin for looks when i did mine... Its about as pretty as 6011 can get i love the stuff cuz its strong, but man it sure is ugly!!
AaronB
i was thinking about doing both sides just to make sure its beefed up
joey0712
O yeah do both sides for sure..... Its not going to hurt anything. Just make her twice as strong.
AaronB
AaronB
this is what I ended up with. tapered the edges to get a better weld area. now i just need to make 3 more
joey0712
Looks alot like what i did.... Keep it up man lookin good and strong!!!!!
TheCookieMonster
i put plates in my thirds when i welded them too. havent had any problems with them. definetly the way to go if your welding them up  :thumbs:
TIMS89CRAWLER
yep did the same on mine f/r never had any problems yet and I dont drive easy on her either! :yupyup:
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
AaronB
joey0712
Lookin good man!!! That isnt goin anywhere! The gears are pretty hard to weld to and make it look nice. Sweet work tho
TIMS89CRAWLER
 :thumbs: that will do pretty means nothing.... ugly and strong just how I like it! :yupyup:
www.choptechfab.com
CHECK THE BUILD
AaronB
well I screwed up on the third.  :rivers: i put the plates too far down, so now when i try to put the axle shafts in they hit the plates.   :maddest:
I think I might just break down and buy spools  :dunno:
joey0712
Ah dang!!!! Im sorry to hear that. What size plates did u use?
RABIDYOTA
if it not 2 mutch grind the axle a little just dont get to carried away
AaronB
Quote from: RABIDYOTA on September 19, 2008, 02:10:22 PM
yeah i thought about doing that. its only going to be about 1/16th - 1/8th inch. im going to see if I can use my buddies band saw.
AaronB
joey0712
hm that is the same size i used... U must have made one kinda small so it went down to deep that sucks!
yotakid707
u can take a die grinder and grind down the plate a little bit so the axle shafts go in or take a little off the axle shafts that way you wont have to get a new carrier and spools
AaronB
finally got my adapter in  :willynilly:
th350 to toy transfer case
AaronB
got a little farther today, partially welded the hanger on.
AaronB
#57
finally got another third welded up and the axle put back together.
joey0712
Lookin good man cant wait to see her as a roller! Keep it up
AaronB
#59
got the front on finally
