Frankenstein II - Going on Tons (Updated 2-5-09)
Started by AaronB, May 25, 2008, 08:48:58 PM
timmyc
that going to look cool when it done  nice work
AaronB
AaronB
got the cases in, just need to make a cross member now.
AaronB
here is what I got for the steering. just needs to be lengthened about an inch.
AaronB
trying to figure out the drive shafts now. how much spline shaft should be showing with truck at ride height?
joey0712
Dang she it gettin close... Is that tranny bolted up?
91 Toyota High pinions f&r.
AaronB
Quote from: joey0712 on November 24, 2008, 08:55:03 AM
Yeah its all in there, just needs a crossmember.
joey0712
O dang.... U been bustin your ace.. What are you gonna do for a crossmember?
AaronB
Quote from: joey0712 on November 24, 2008, 11:05:02 AM
Yeah I was trying to get as much done as I could before vacation. not sure yet about the crossmember, im going to try and make it as flatbelly as possible but well see.
LilChief87
hell yeah if you dont mind cuttin up the floor a lil make it complete flat belly
AaronB
Quote from: rebeltoy83 on November 29, 2008, 09:45:23 AM
Yeah I want to, the only thing that will hold me back a little would be the motor mounts, but ill figure it out.
joey0712
I donno if u really have to do much to them... They should move enough
AaronB
this is as good as its going to get without lifting the motor.
Ramrod
that tcase is down farther than stock, lift that sucker
AaronB
Quote from: TEAM RAMROD on November 29, 2008, 07:41:19 PM
that's the same thing I said. the problem is the motor would be at a bad angle and the oil wouldn't distribute right. Ill have to lift the motor, which means the motor mounts will have to be re fabbed, which means the hood would have to go.
AaronB
#166
got the flat belly started, bunch of cutting went through 3 cut off wheels.
AaronB
here you can see its flat
AaronB
but here is the problem, the motor is about 7deg. to high in the back.
joey0712
I keep forgettin u got that small block in there...... Cuz a guy i know did a flatbelly with a 22re without touching the motor mounts...... thats a  pita if ya gotta move them
*** YELLER ***
wow just read yer build and WOW its coming along nice good work bro  :biggthumpup:
:usa: :beerwhack:
except BACON
AaronB
Quote from: joey0712 on November 30, 2008, 07:02:56 PM
yeah, a lot of guys with stock motors have left the mounts alone. But from what i've been told the chevys need to be level.
AaronB
Quote from: **YELLER** on November 30, 2008, 07:32:36 PM
:usa: :beerwhack:
Thanks, its getting there. hopefully ill have it done before the first of the year.
jedrattle
 Looking good!! Bring down to the hammers when done!! :greengrin:
`87 runner....it was stock....now sas'd, 37's, duals, geared/ locked, 10in bob, half doors, rock lights. etc., etc.,.........coming soon a 3.4 swap!!!
http://board.marlincrawler.com/index.php?topic=39332.0
www.rockbrawlers.com
AaronB
Quote from: jedrattle on December 02, 2008, 08:42:39 AM
I will have it there by new years hopefully. What about you?
joey0712
So whats the progress ????? what ya workin on   :eyebrow:
AaronB
Quote from: joey0712 on December 02, 2008, 09:54:47 PM
havent worked on it in a couple days, been putting in too many hours at work.
joey0712
I hear ya.. Ive been workin like no other we are kinda busy rite now. Im sure it willl slow down for winter tho. Gotta make it when ya can!
AaronB
problem fixed, put on a 3" body lift. Thanks Lilbuddy.
now I just need to figure out how im going to modify my motor mounts
4.3 headache
Man looking good. sucks about the body lift though. but i've got the same deal. eventually i'll cut out the tranny tunnel but i don't want a hood scoop. :confused:
heres my t-case mount
all i want is a little more than i'll ever get!!
