Frankenstein II - Going on Tons (Updated 2-5-09)
Started by AaronB, May 25, 2008, 08:48:58 PM
AaronB
thats pretty much how i was going to do it before the body lift. looks good.
what did you do for motor mounts?
4.3 headache
 my motor mount flanges are from downey. they suck. the mounts themselves are factory chevy.
they sit on top of the 22r perches and have a long flange that spaces them back for the 4.3. I welded a piece of angle iron onto the frame for support so they don't bend.
all i want is a little more than i'll ever get!!
AaronB
ah, there different then mine. I need to figure out what im going to do.
gotrocks
Here's a mount idea for you.  This is what I do on customers rigs.  Its really strong and pretty simple do do.  It consists of 1.5 tubing .120 wall and 1/4" steel along with YJ leaf spring bushings.  Just cut a plate that bolts to your block along with some tabs for that plate.  Cut down the tube so its the width of your bushings then install those bushings and weld the tabs to width.  Slide your motor down and figure out how long the tube needs to be and cut to length.
Sorry I'm not trying to tell you what to do just an idea.  Its just a really easy way to get your motor in and put it where you want it instead of working with the stock stuff.  It'd allow you to lower you motor and place it easier without to many issues.
AaronB
Sweet, that looks fairly simple. thanks for the help
gotrocks
:thumbs:  Really simple and stupid strong.  Not forgetting to mention ease of installation.
AaronB
well.........
Im kind of thinking going a different route with the build.
60/14 bolt combo.
I would love to run 39 or 40's
what do you guys think?
gotrocks
heck yeah now your talking.  Go with the 60/14b and go 42's.  You need to in order to get the same ground clearance that 37's will give you on a toyota axle.
Trust me you won't be dissapointed if you go that big.  I sure don't miss the toyota axles when I'm in the rocks.  I just blew a toyota hub on my tacoma this weekend in the snow.  Wouldn't have happened if I had 1 tons.
AaronB
the only weak spot i can see happening is the output shaft on the toy case. would a 42 really make that much of a difference than a 39 or 40?
gotrocks
Yes it does.  The guys I wheel with have 39's and 42's.  Just having that 42 on the same obstacle as the 39.5 (I just call them 40's) can make the difference on making it and not making it.  This also goes hand in hand with wheelbase.  That extra 2 inches can either hinder you or help you.  The same goes with a 35 vs. a 37.  Every bit helps.
gotrocks
AaronB
cool, i got to find some one tons first, then i can think about the shoes.
AaronB
no going back now.
LilChief87
EarlKann
What the heck.  Everybody is going to one tons now?   :dunno:  I suppose there will be some deals on Toyota axles at least!  :thumbs:
AaronB
Quote from: EarlKann on December 15, 2008, 10:15:27 PM
it wont be right away, id like to get a couple wheeling trips in first.
AaronB
got it tacked up a little bit tonight.
LilChief87
lookin goodwhat are you guna do wit the tail light buckets
AaronB
Quote from: rebeltoy83 on December 16, 2008, 06:59:43 PM
there going back on I just need to do some more trimming.
LilChief87
oh ok good i was guna say itd look goofy haha
AaronB
just confirmed im picking up a 14bolt on Thursday.  :smack:
LilChief87
you lucky sob haha ill trade you a  :beer: for it lol :disturbed:
gotrocks
Looks a bit tight in the garage there.  Good thing you bobbed and dovetailed the bed you can fit it in.   :rofl2:
LilChief87
yeah looks like hes guna have to clean it up a bit to fit the truck in the garage if he wants to do full widths
AaronB
Quote from: gotrocks on December 16, 2008, 07:23:04 PM
no joke. im constantly tripping over crap trying to work on it. I need a storage shed badly.
AaronB
Quote from: rebeltoy83 on December 16, 2008, 07:27:27 PM
its not going to fit with full widths, i barely make it right now.
LilChief87
yeah i can see  you got like 2 inches of room extra on both sides
boggerunner
you have alot more room than my garage
