Author Topic: installing CB / anteni  (Read 28945 times)
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« on: May 07, 2008, 05:58:35 PM »
Well i decided to clean the shed and i found my old cobra 25 LTD.  So i went 2 the Cb shop had them check the radio out ( been siting 12yrs )  also picked up a 3ft firestick  and a mount and 18' of coax  for  55$
I decided 2 mount it batween the cab and box  and this required some modification  :flamer:
« Last Edit: May 11, 2008, 01:27:29 PM by unclejpl4x4 »
Re: installing Cb / anteni
« Reply #1 on: May 07, 2008, 06:01:13 PM »
i thought you had a cobra 21  :headscratch:
Lady Di
  • Goddess of Mud
  • Internet Lassies
  • Female Posts: 299
« Reply #2 on: May 07, 2008, 06:08:22 PM »
:psss: Cb?  you mean CB? and Anteni... is that a hot Italian actor?
And why is there a polar bear scratching his head?
JK! :rofl: Carrion!
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #3 on: May 07, 2008, 06:08:58 PM »
Now  I took apart the whole dash trying 2 find a place 2 stick the 25  :_order:   No good
My buddy gave me a bra new in the box  cobra 21---- well if you can consider that new.
Now i am anal when it comes 2 a clean cab/install i think im gona mount the 21 under the radio.
here are some more pics  get more 2marrow darn sun went 2 sleep
The first pick i took the cut off tool and trimmed some metal and yanked out the foot heater tube  :cheese:
and yes that dark spot on the right side under the CB is where i melted the carpet  :hammerhead:
« Last Edit: May 11, 2008, 01:28:04 PM by unclejpl4x4 »
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
Re: installing CB / anteni
« Reply #4 on: May 08, 2008, 10:32:15 AM »
Ok suns out time for CB insulation
So with the dash apart  time 2 pull out the radio.  This is where i separated the front 2 plates for cutting.
I used a air cutoff wheel   bench grinder and hand file.   Using the CB as a template i marked and cut  then filed till i had a nice fit.
Note: Do not use 2 much pressure or you will break the metal like i did then have 2 weld it.
Note: becareful not 2 damage the outside cover when cuting.
Now i got run 2 the hardware Store for metal so i can mount the BC 2 the dash brakets.
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #5 on: May 08, 2008, 10:39:23 AM »
 :headscratch: umm wouldnt it have been easier and quicker to  get a magnetic mount atena and just stick the Cb under the driver side seat next to the shifter   :dunno:
IF YOUR LOOKING OUT THE FRONT OF YOUR 4X4 AND YOU CANT SEE THEN JUST TURN ON YOUR WIPERS. BUT THEN THINGS GET ALL MESSED UP LIKE IN LIFE.
WHEN YOU GET TO THE END OF YOUR ROPE JUST THINK THAT ALONG TIME AGO  YOU WERE THE FASTEST LITTLE SWIMMER TO THE EGG
08:55:22 PM BeccaLoo24 – i like to screw things
$99 scratch and dent drill press has drilled more holes than Ron Jeremy.
http://board.marlincrawler.com/index.php?topic=48342.0
[img]http://bo
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #6 on: May 08, 2008, 10:42:21 AM »
You missed this part>>
Now i am anal when it comes 2 a clean cab/install :moon:
Do you have a dartboard in your shed joe? what else u hiding in there? :eye:
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #7 on: May 08, 2008, 05:06:20 PM »
I did not get much done 2day  :down:  here are some brackets i bent-up  + the speaker   I got go get some screws .
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #8 on: May 08, 2008, 07:23:48 PM »
This is looking pretty nice. Keep it up!
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #9 on: May 11, 2008, 12:54:33 PM »
Ok shes done :thud:    I ran in 2 a problem and had 2 get a new CD/stereo and also picked up the adapter for the outer space radio  so $140  i did not wanna spend.
I had 2 cut more of the dash then i wanted 2  :willynilly:
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #10 on: May 11, 2008, 01:03:09 PM »
pretty sweet dude.
« Reply #11 on: May 11, 2008, 01:18:55 PM »
looks good, i cant mount my cb  there,  darn first gens :snare:
« Reply #12 on: May 11, 2008, 01:22:06 PM »
so when can i expect  the cobra 29  in the mail  :disturbed:
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #13 on: May 11, 2008, 01:26:00 PM »
I am having a problem with static feedback threw the external speaker when the CB is off ( everything off radio,truck )
 i  got a arc when installing the assembly but the ground was not hooked up/ key was on ACC   so the radio was looking for a ground.
I check all the wires i could see and i see no chafed power or speaker wires.   I soldered all the wires/heat shrink.
But if i unplug the mic it gose away   or pug in the mic from the cobra 25   but that has it's own problems.  Im gona pick up a cobra   http://www.cobra.com/index.cfm?fuseaction=product.display&Product_ID=75&category_ID=34
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #14 on: May 11, 2008, 01:27:10 PM »
ya cobra 25 ltd classic  i must of been :smoke: that day.
« Reply #15 on: May 11, 2008, 03:18:20 PM »
:headscratch:
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #16 on: May 11, 2008, 03:27:57 PM »
:dunno: don't ask me, I think hes a little :screwy: or maybe :boozer:
Dr.Maxwe001
  • Male Posts: 627
« Reply #17 on: May 12, 2008, 06:09:58 AM »
he's not a little  :screwy: he is alot :screwy: and thats not all he is alot  :stopit: too
[img]http://bo
PA_taco_13
  • Male Posts: 309
  • Member since Dec '05
  • PA Muddin
« Reply #18 on: Dec 19, 2009, 04:00:36 PM »
looks nice joe!     :thumbs:   hope mine turns out the same
learn the hard way
"my dixie wrecked"
east coast crawler
PA_taco_13
  • Male Posts: 309
  • PA Muddin
« Reply #19 on: Dec 19, 2009, 05:16:49 PM »
Hey Joe, I notice that your CB sticks out just a little bit.  And here is a picture of my one buddy's cb install.  His sticks out quite a bit.  He said his sticks out because of the way his cables hook up.  Did you have that problem?
learn the hard way
"my dixie wrecked"
east coast crawler
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Drinking me beer
« Reply #20 on: Dec 19, 2009, 05:55:09 PM »
Mines the same way Brian.
b-radhutch
  • Member since Aug '09
  • my first yota
« Reply #21 on: Dec 19, 2009, 06:14:56 PM »
the CB unclejpl4x4 put in is shorter and has less nobbs so im asuming that your CB could be longer?
unclejpl4x4 [OP]
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #22 on: Dec 19, 2009, 07:10:34 PM »
ya  the cobra 25s are big    thats why i got the 21 shorter smaller..........    i suggest before you hack the dash  to find a good high quality/output compact   and not a behemoth  like the one in the pic :boobs:
reddevil500
  • Turtle Points: -1
  • Male Posts: 45
  • Member since Dec '09
  • T O Y O T A lasts forever!
    • I Dreamt About Her!
« Reply #23 on: Dec 19, 2009, 07:22:01 PM »
is there a specific way to talk to somebody on the CB when your say in trouble o you just go for it as if were a phone?
Craigslist!
b-radhutch
  • my first yota
« Reply #24 on: Dec 19, 2009, 07:27:56 PM »
channel 9 if i rember is emergency i have the 25 channel cb from cobra more than 15 years old
reddevil500
  • Turtle Points: -1
  • Male Posts: 45
« Reply #25 on: Dec 19, 2009, 07:32:56 PM »
yeah but you just start hollering for help (I need help stranded flipped over on so and so trail about so so miles Northwest from so and so) example?
Craigslist!
b-radhutch
  • my first yota
« Reply #26 on: Dec 19, 2009, 07:49:17 PM »
not sure never had to do it
reddevil500
  • Turtle Points: -1
  • Male Posts: 45
« Reply #27 on: Dec 19, 2009, 07:51:17 PM »
i guess thats a good thing!
Craigslist!
b-radhutch
  • my first yota
« Reply #28 on: Dec 19, 2009, 07:55:48 PM »
i guess so lol try posting a topic hb it in CB / Ham radio tech
reddevil500
  • Turtle Points: -1
  • Male Posts: 45
« Reply #29 on: Dec 19, 2009, 07:57:04 PM »
will do, good looking out!
Craigslist!
Last post Feb 12, 2004, 12:17:16 AM
by WHITE_TRASH
Last post Mar 30, 2005, 11:50:45 AM
by BLACKDOG
Last post Apr 24, 2011, 10:16:43 PM
by 85_yote_94
Last post Jul 25, 2007, 01:11:57 PM
by MiniSimp
Last post Sep 19, 2008, 02:12:53 PM
by taco522
