put it on the outside of your truck
make it out of metal, stay away from PVC
Make your joints nice & tight before welding
what ya think about making it removable.
Do ya think 2" to 3" is ok between the body and cage to keep the cab from hitting when flexing or can get i get closer 1" to 2"?
I would build it as close to the body as possible and then weld tabs between the body and the cage every 4 inches to make them one solid piece. But I don't drive on the street either.
Mini, would you solid mount the cab too?
lost on that mini
I would try to keep it within 1/2"-1" from the body for a welded on.For a removable I think it would depend on the the design you come up with. Could make it a two piece (front and rear) that bolt together and still be able to keep it at about a 1" clearance. Weld on is the way I would go for better strength
had to be in the mix somewhere
Don't:
Started by royz Parts For Sale
Started by shooter Engine
Started by toynizzy Project Research and Build-Ups
Started by TheBandit « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by lickady split Toyota Pickup/4Runner Tech 1979-95
