wanting tips on building exo
Started by toynizzy, January 30, 2006, 08:26:08 AM
toynizzy
well once i get my susp on im going to stat my exo and tube flatbed.im wanting any tips and tricks that you all might have that might make it easier.if any of u have built your own please advise on any things that i should do to help get it right the first time thanxx
        brian
85 xtra cab pretty stock for now but lots of stuff to come!!
yotaboy79
#1
if your using seemed tubing try to keep the seams on the inside of the bend and if you have to cut and splice any peaces togeather use a peace of tubing that will fit inside of them and then hold about an 1/8 gap between the two peaces your trying to join and that will weld the the peace inside and the two peaces you get full pen with out burning through and dont grind any more weld than you have to the more you take of the more you weakin it and if your bending a complicated part or your not used to the bender or you not shure about the design yet use i cheap peace of thin wall tubing like .065 instead of the spendy stuff oh and measure 2,3,4 even 5 times take your time and be creative and most of all have fun
yotaboy79
oh and if you havent already you might read this this is what got me started
http://www.pirate4x4.com/tech/bendin_tube/index.html
and remember your life may depend on that tubing
blackdiamond
Put it inside the cab...it looks better  :gap:
toynizzy
my son needs a jungle gym to play on when im not driving it lol
KYOTA
like yotaboy suggested read 'bendin 101' and then look thru the exo thread in the Toy FAQ (on pirate also) to get some ideas
