It was just crazy to see this deer leap all suicidal style off this embankment right in front of us.
Yeah I forklifted it on the barrel. Anyways...something in the electrical system is keeping my AC pump from kicking in. I think it's the OEM switch in the dash is bad. The switch lights up, but no power to the pump. So I cut the wire to the pump and went direct with 12v and the clutch kicked right in and it started workin. So I'm just gonna wire in my own switch to the dash. I didn't get any plumbing done today since I was trying to troubleshoot that. And I noticed my power steering belt has flipped itself upside down and also jumped pulley! It decided it wants to be upside down and run off the crank pulley that runs the AC pump. SoI put it back in it's place, I'll have to watch that. As expected theres gonna be alot of little bugs to work out. My new front shocks have shown up, I'm just waiting on shock tabs and I'll get some dampeners on the front. It's comin along really good.
i had a belt do the same thing, it happens when u run a belt to wide for the pulley. i was running the ac belt for the alt and water pump.
DO NOT BUY ONE FROM ANY PLACE BUT TOYOTA OR NAPA! all other places only sell one size belt and it is 1/16-1/8in TOOOO WIDE and almost an 1in TOO LONG!!I almost got in a fatal accident because of this.I went through 3 belts before i took it in to the Toyota Shop and they sepnt hours and getting specs from everyones belts and determined NAPA sells the correct belt.it all started when I was doing 70mph on a 6% downgrade and my PS belt flipped and jumped off. It shredded all three of belts... and when it all shredded and went flying around under the hood. it tore through my alternator sensor wires and deadlocked my engine at 70mph and locked my whole truck up and sent my flying into the ditch.So I HIGHLY recommend you ditch that belt all together! Go with someone else.Goodyear Gatorback Belts... ARE THE WRONG BELTS!
dude that fully sucks and is super shitty
Just tyin up some loose ends. Finished the cage in the front. And Dialed in my rear suspension and added the much much needed bumpstops and limiting straps.
Started by Beast2588 Chit Chat Camp
Started by MiniSimp Chit Chat Camp
Started by TexJeff87 Toyota Pickup/4Runner Tech 1979-95
Started by alex-toy83 Engine
Started by smitty9902 General 4WD Discussion
