just wondering why you need double low 2wd?
Helps on granite when turning.
i'd go with gears. better if you ever plan on driving it on the road too. a two piece front seems a little scetchy. i'd be afraid of reaking it.
trust me, if Gittinit builds it it will work
i guess it would be cool if you had a rear driveline disconnect and needed the low to the front.
3rd case:Pros: Equal length driveshaftsMore optionsNo case grinding20* clocking with 2 MC-R10 adapters248:1 crawl ratio with W56/RF1A/RF1A/RF1A/5.29'sOption to have 2169:1 with 4.7's in all three cases Cons:Change crossmember and rear mounting point may interfeer with horse collar crossmember and gas tankDrivetrain will be around 53" long from bell to flangeRear case shifter will be by seatbelt mountswill have to buy a twin stick anyways for the 1st/low/low/low/2wd optionChange both driveshaft lengthNot as easy as installing just gears
ok maybe am just but why would you need a two piece driveshaft for it to work?doesnt marlins truck have 3 t-cases? i didnt know you had to have a two piece driveshaft..
then do it and go for the 2169:1 low
Three cases is given the option of 4.70 gears in the rear case. Your gearing options are essentially the same.2.28, 4.70 & 10.72 vs. 2.28, 5.20 & 11.85 which isn't enough difference for the added work.
Start a price sheet. Should be interesting. would you twin stick the 3rd case?
It's a difference of about 23:1.It just depends on if you would rather put the extra work into a 3rd case, or maybe spend a little more money for gears and a twin-stick.
i ran 3 cases in my 79, it worked great, and all were 21 spline, never broke anything, and i was really really hard on it. The shifters made a great arm rest too.
Your third case input shaft would have more torque on it than putting 4.70 gears in the front case of a dual setup. You would need a 23 spline I think.
i vote 3rd case AND twin stick
I was hoping you would chime in. Your one of the few I know of on this forum who isnt scared to run 3, 21 spline cases. I wonder why your not still running this setup now? Hmmm thats a good piont. I wonder how many people who run low gears in the crawlbox, have broke 21 spline output/input shafts. Didn't Big Mike do some research on this rescently? I'm gonna have to find that thread he started.
Started by foxfab Parts Wanted
Started by SQUIRREL MONSTER Project Research and Build-Ups
Started by toyotawheeler Parts Wanted
Started by hossman777 General 4WD Discussion
Started by 95toyrunner General 4WD Discussion
