85 Red X, My son is now cancer free!!! Back to wheelin!
Started by Thomas P, April 13, 2008, 10:39:40 PM
808
85 toyota pickup(sold)
92 toyota ex cab pickup SAS'd 4d's 27 spline chromos 5:29's and lockrights front and rear arp knuckle studs
my build: http://board.marlincrawler.com/index.php?topic=44691.0
808
to do double beadlocks on 4 15" rims its just a little over 50 bucks. why didnt i know about this before?????
how easy was it to do mike and thomas?
NorCalToy
The other way i saw to acturately mark the spot for each new screw was to use a u shaped thing flipped upside down. you drill one hole where ever then stick the tool into the hole and scratch off the next spot to the next screw. super crappy description...
so instead heres a crappy drawing  :biggthumpup:
:flamer: IFS
Thomas P
Quote from: 808 on November 02, 2009, 11:44:56 PM
it was $70 to my doorstep foir 15", and its pretty simple, you just have to do some simple layout then screw and screw and screw....... it would take about 6 hours if i didnt add the extra to the outside
'14 Camry SE
SCX10 Honcho on roids!
808
man that is so cheap! i have got to get them. do you have to take out the bolts when u change the tire im guessing?
how is the rtv holding up for leaking purposes
Dingman.
Well the screws them self arn't supposed to leak, but the rtv is there for extra assurance against them..
P-DiseToy24
Are they just self tapping screw cause I bet a hardware store would be real cheap...
pumkin toy
Quote from: P-DiseToy24 on November 03, 2009, 02:40:27 PM
if you read the article on pirate he says that you cant just use any self tappers, you have to use fine thread ones so it seals better and has less of a chance to strip out.  I'm sure you could find them at a hardware store but obviously inchworm knows which ones work best so it takes all the guesswork out!
97 4runner Limited
Thomas P
they are self drilling, and self tapping, fine thread to prevent stripping, and to make a good seal, and are galvanized to prevent from rusting, i havent aired up the first tire yet, im hoping to get out there and do the inner bead on the first tire then air it up, if it leaks oh well, it shouldnt be a fast leak, plus i have on board air.....
'14 Camry SE
88Rokyoat
beadlocks look good. I have a buddy that runs those and likes them, so far after a couple runs. They seem like a lot of work but they are diffently cheaper than weld on beadlocks.  I think when I beadlock mine I am going to do weld on outer ring and the screws on the inner bead.
truck looks good tho. :beer:
stupid people shouldn't have kids.
P-DiseToy24
X2 Im puttin those bad boys on the inside of my locks.
46&2
That is a pretty sick idea. Going to have to get these for my rig as I do a lot of snow wheeling here...
Dingman.
They seem like they will work good.  Im gonna wait..  I have outer beadlocks now and if i have problems with the inner beads then ill get some if thomas is stoked on his.  :yupyup:
ToYocRawleR
Thats sick thomas, have you aired em up yet and see how they work?
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
P-DiseToy24
Thomas P
i got one aired up tonight ill let you guys know tomorrow...... im down to 15-20 mins per bead, should be done tomorrow night if i can keep on it  :crossed:
'14 Camry SE
swapped89
Awesome idear cant wait to see how well it works. I  read the pirate thread and it seems promising.
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
Dingman.
 Only two more to go..
Thomas, ill swing by after work and we can get those other two tires done..
I still need to mount my 40's so i can trim the fenders to clear for this weekend.
And we need to replace the coolant line on tonya's 4runner and weld that bumpstop on.
And OBA write-ups soon!!!!!
yota_krawler
damn thats bad ass thomas. i havent seen that before. def need to get some when ready!
86bobbedtoy
cant wait for the snow.
I think RedX is gonna be the shiz.
and pull my ass out
Thomas P
nah youll be fine, as long as you get some 30 splines... i tried out my 2 wheels with the beadlock screws, they did good and held air, they have a slow leak but did affect the run, hope to get the other side done this week
'14 Camry SE
Thomas P
so its been a week since i aired up my 2 beadlocked rims, one was flat today and the other had only lost the one pound!  :biggthumpup: the one that went flat never had been tested for leaks the the other
'14 Camry SE
Thomas P
Alright, ive got a winter punchlist to get done before i buy my new house and have no time for the rig.... Ive got 2 weeks
Flush heater core, and get some heat rippin'
Do the other 2 beadlocks, and get rid of the leaks
Fix my toolbox since I overfilled it and  blew the bottom out
Oil change, clean k&n filter
Remove cruise control, and alarm crap since its a garaged rig now
Now that im out of the dusty season I need to clean up the cab spotless
New windshield wipers
'14 Camry SE
Thomas P
should be able to get it done this week, its nothing major....
'14 Camry SE
yota_krawler
Thomas P
nah its just cracked, not broken, as long as it keeps stuff out its all good, especially for an offroad only rig, i cant wait to get into our new house so i can have my trailer there and make this thing a green sticker rig!!
'14 Camry SE
Thomas P
'14 Camry SE
