some half doors
Started by DieselD, March 02, 2008, 08:16:38 PM
DieselD
Started my half door project. body people will probably be scared but its turning out well I think. slightly differnt than most on the road...I also did not like the look or function of them being cut super low. some might argue this is not much of a cut but it should be alot better than a full door in terms of outside point of view. It will also give a arm rest since its about that right height
I spent alot of time drawing to figure out what I wanted, height, width etc. here is the rough cut
the center section I had planned just to fold over to have one less thing to cut and weld. well it didnt work out as planned. about an inch shy of what i needed. It was hard to measure the width of the door before cutting it apart.
the inside is a typical door with all the moldings and holes given for access.It would have been too hard to try and fill everything in to the very uneven inner sheet metal. i cut it all out of filled it in too.
this is where it sits now. still have to get the latch in, maybe a cup holder then weld it all. I did run out of 18guage sheet tho. my scrape piece I bought was not quite enough once I messed up the center section.
OOPS
Looking good, but you are wasteing some good storage space.
twistedtoy92
BLACKDOG
Quote from: OOPS on March 02, 2008, 08:35:33 PM
:yupyup:
I like how you did yours, I may be hacking mine up in the near future, to take advantage of that space :gap:
              -Ronald Reagan
Doof
i like em both. a cup holder is key for sure
Padded cup holders and storage space would be a pretty bitchin combo!  Yours don't look hacked to me, but I aint no body man either.
DieselD
sick! thats the best inside finish Ive seen. I was planning on doing that same thing for a trim panal. you have any inside pics of the cubby hole? unfinished?
yeah I had thought about storage but kinda said f it cause it seemed like alot more work to get in there. 4 more peices to fit and cover. dunno Il think about it today and maybe redesign a little. I am diggin how light these doors are now tho, a full door is heavy!
I really did not want a speaker since it would have to be wired and have to richard with that when swaping. not really need it. Its a trail truck so the cb prevails mostly. I do need to swap my manual stuff to my auto full doors.
OOPS
Thanks
Sorry no pictures. I cut the inside of the door as you did, used a piece of aluminum plate, built the box, and pop riveted it to the panel and pop riveted the plate on the door. The reason I used the aluminum because it was left over from when I made the deck on the flatbed. The panels are made from 1/8 inch Masonite and upholstery vinyl.
I do not like cup holders in the doors because of the dust and sun, my cup holder is between the bucket seats.
As far as the wiring for the speakers, this is what I did.
Talon84x4
Nice doors. I agree on the storage space, even if for nothing more than trash   :dunno:
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
Redbeard1
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
OOPS
#10
Quote from: Talon84x4 on March 03, 2008, 11:55:37 AM
CD's and sunflower seeds use to be cigarettes but I finally quit.
BLACKDOG
When I put speakers in my doors, I just ran the wires through a hole near the hinge, used some quick connects, and stuck them back through the hole.  When I switch doors, I just pull the wiring a bit, and disconnect the quickconnects, and then connect the speakers in my full doors the same way. :thumbs:
              -Ronald Reagan
DieselD
So far about 8hours into this project on one door...I hope to cut the time in half on the next one. I got most of the door welded up and ground but still need to do a couple small things including build a door panel for it.. I dont have my hinges in yet but I had to take the door off anyway so figured why not mount it up to see the fit
filling in the hole for the lock and door handle
I kinda messed this up, remember Im not a body man so this is good for me. might be hard to see but if you look close and feel it with your hand you can tell its not even. probably took too much off trying to flush out the welds. I could run some filler to fill in my screwups. I am trying to keep in mind the chance of getting smashed on the rocks and feeling bad about spending hours on body work so I think a little rattle can primer in flat tan or white will do the trick.
I love the cut. I can lean out and see so much more than a full door without the ugly look taking the doors all the way off. I think the cut height is perfect. only catch is the top is not perfectly flat and got a little heat warpage. again me being anal. I have not aligned the door in this pic. just bolted it on for a test fit.
inside shot of height and handle location
montanatoy
looking good i will be doing that real soon to mine and my sons truck.
toyotas are like tonka trucks of old built to beat the hell out of
DieselD
interesting tidbit.....11lbs lighter per door
Doof
Doof
can i get your measurements?
with the angle of the --> \___/  <--
DieselD
Ill measure in a bit....
here is the finished deal. got my hinges on and aligned for both sets of doors. swaping is a breeze.
here I was testing out a flat tan...but think I will stick with primer. nothing is really going to match.primer matches the interior tho
John Doe
Perfect height  :yesnod:
X2 on the measurement request.
Talon84x4
Fearofrunner
X3 on measurements please :) Those look bling bling for sho
DieselD
hope this helps some with building their own. I looked at alot of doors and didnt like much of what i saw. I took a little bit of design aspect from the countless Ive seen and tweaked it to my liking. I think it came out to be a good looking door and differnt than most. glad you guys like it.
case in point not to stress on getting it perfect if your going to be in the rocks. kinda glad I had these to bang up instead of my good full doors I hit it right where I was unhappy about my filler panel for the latch and lock. solves that! I love them on the trail tho. I can see so much more and they are comfortable. They give much needed protection from brush, water/mud flying up along with cow pies......
Yota87Truck
like the half doors... and i like the idea of keeping the whole frame of the whole door so it covers the molding all the way around the edge
DieselD
I dont like them without the frames. looks incomplete. IMO
Steve_925
looks really cleen. i just did my second set, my first doors where really low this time my new door is like yours, cut pretty high. i would rather have alot of protection and sacrafice a little sight. mine doesnt look so clean though
UA 342
STEAMFITTERS
Steve_925
cup holder a must
UA 342
STEAMFITTERS
DieselD
If I had a cup holder I would have had a big junk of cow poo land in my monster on its way to my windsheild
but yeah I think i will add those later...
DieselD
door panels...need to find some vinyl to cover them with
CRS
Doors look killer glad to see someone else took the time to some nice doors instead of the usual hack jobs :beer:
not to hijack but i went a different route with my inner panels vinyl and fabric is to much of a pain tried it and wont ever again. Good luck
IN LOVING MEMORY OF JAKE. MY BEST FRIEND AND COPILOT
                  WITH ME FOR A MILLION DAYS
                         2-15-05  4-12-06
DieselD
interesting, how did you finish yours? sheetmetal and filler? looks awesome tho! does it have the hollow beer can sound when shutting? I know mine did before putting a panal on it
my panel is going to be flat and simple. I should be able to just get vinyl, wrap it on my base fiberboard and glue/staple and be done. screw it to the door with self taping screws. Im not going for show quality but something thats fairly clean. its a rock crawler not a show truck. I might even just bring it to  shop and throw the guys a few bucks. We have a interior shop we deal with so should cost much
