Author Topic: carburetor ?  (Read 1789 times)
toby
  • Male Posts: 276
  • Member since Aug '07
carburetor ?
« on: Feb 28, 2008, 03:54:26 PM »
Is there a bushing or seal on the main shaft, the one that connects to the throttle cable? If so how do I repair or replace it?
I'm not as good as I once was, but, I'm as good once as I ever was.
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
Re: carburetor ?
« Reply #1 on: Feb 28, 2008, 05:21:56 PM »
I don't believe there is a seal in the baseplate for the throttle shaft. If it is worn out and causing a vacuum leak you may need to replace the carb or try lubing it with grease to help block the leak.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: carburetor ?
« Reply #2 on: Feb 28, 2008, 06:34:56 PM »
or  you can find another  carb base  and  swap it out  if your carb  works really well :dunno:
toby [OP]
  • Male Posts: 276
Re: carburetor ?
« Reply #3 on: Feb 29, 2008, 11:51:12 AM »
I've got a couple spare carbs, I was really hoping i wouldn't have to take it off again.
Last post Jul 18, 2005, 12:24:36 PM
by 4XFun
Last post Jan 25, 2009, 02:22:04 PM
by riverrat504
Last post Feb 18, 2010, 04:21:38 PM
by yoda87
Last post Aug 22, 2010, 09:28:21 PM
by RN37DD
Last post Jan 12, 2020, 03:25:13 PM
by PuertoFrito
