What do you have for a tow rig and why??
Started by lowgeared, June 27, 2004, 07:28:17 PM
yota_krawler
bump
i dont have a tow rig but not sure what to get. Gas, diesel, crew cab, single cab etc
axled89
that gmc yukon is a nice rig i think comfort/ reliable/ and holds all the gear.
i love oregon wheelin.
illinoisyotadriver
99 freightliner fld 120 with detroit d60 13 speed  48foot flatbed has all the power and has a shower
yota_krawler
Quote from: axled89 on January 11, 2010, 04:59:39 PM
what yea? does it have the 350? I want a yukon.
red
he's talking about this one i think. great setup
Quote from: Dirty White Boy on August 22, 2006, 05:00:04 AM
My tow rig:
2001 Yukon XL 4x4 8.1. Tows excellent. MPGs, well, it sucks. 7 mpg is the worst, 12 is the best.
The wifey wanted something nice, I wanted a tow rig. We compromised and got this. Oh well, I guess I can wait a few more years 'til I can get a pickup/gooseneck rig.
read and comment :whip:
USAF EOD tech
axled89
yea that is what i'm talking about.   that's a sweet set up.   what motor is the 8.1  is that a diesel or a 454?
freds40
Quote from: axled89 on January 12, 2010, 12:52:26 PM
It's a 496 gas motor
I run a '97 Ram 5 speed with a Cummins. Went that route for strength and durability.
"between projects"
red
496, replaced the 454 when gm changed body styles. more powerful and slightly better fuel efficiency than a 454. similar fuel economy to the 6.0L but with more power
USAF EOD tech
axled89
#98
DAMN!!! that's pretty big.   is it a good gas engine and durable.  as far as last long time or what?
and do they make these in diesel?
red
its got a good reputation with a little bit of an aftermarket available.
the yukon xl in a diesel? not from the factory since the 2000 body change but there are companies that convert them, aint cheap though.
USAF EOD tech
Toymin8r
2002 Chevy Silverado 2500HD Extended Cab 4x4 Duramax/Allison  With Edge Juice box.      I'd put it up against almost any work truck in the cost per mile to operate.   I bought it new and put 175k on the odometer.  It gets about 19MPG empty and about 14MPG towing my trail rig.
In that time I've replaced:
Thermostats - (when it was new uner warranty)
Rear Driveshaft U-joints
Fuel Injectors (under warranty)
Rear brake pads
Right front unit bearing
Both Batteries - (last year)
Alternator - (last year)
3 sets of tires
Other than what is listed above and fluids that is all.
QuoteBeccaLoo24 – i can toss grown men.... so dont doubt me
nwx
I tow with an 82 Chev crew cab dually (454 gas). Tows my 4runner (16' trailer) no problem. I am adding a camper this year so we will see. I am also tired of the tent thing
904x4yota
 I tow with a 98 Dodge Cummins 12 valve 5 speed 4x4 quad cab long bed.  I get around 20+ mpg empty but not sure loaded never checked.  I have only replaced the clutch from a single factory unit to a Dual disk clutch because I turned the fuel up and the single disk would slip. Other than the clutch which is my own fault, 208,000 miles UNTOUCHED.  Cummins all the way. :thumbs:
90 toy. Marlin cage, Marlin High steer, Long axles, Hydro assist.
furrballs95
I tow with a 2004 dodge cummins 6spd, smarty tuner, southbend cluth, boost fooler, fass fuel system,intake and exhaust, exhaust temp and boost guages. the truck runs and tows amazing tons of power and i would never own any other diesel. CUMMINS ALL THE WAY BABY.  :beerchug:
95 Toyota p/u 3.0 v6. Marlin SAS with 5"springs, 30 spline bobby longs, and a welded V6 third in a trussed 85 front axle. 529's front and rear, Marlin rear kit with 5" springs, lockrite rear locker,  36"  IROCKS on 15x10 black rock crawlers, custom front and rear bumpers,
muddytaco
93 3/4 ton suburban, mostly cause i traded for it and have nearly nothing in it, basically free
95 tacoma 5" revtek/bilstein detroit locked 9" with drilled and slotted rotors front and back, 8000# mile marker winch, 16" crager crawlers, too much other crap to mention
96 t100 2wd (soon to be sasd i hope) - dead
85 efi 4runner
01 sequoia
Blingn
00 f350 v10,a/t,4x4 fully loaded..Just got back from Moonrocks and it was fully loaded down.
GreenYoterKrawler
Id rather dump that 10+ grand into my rig and drive it  ::)
I blame the automatic transmission for the wussification of America
If Its got tits tires or electronics, your gonna have problems
I drive a jeep cuz toyota doesn't make strollers
pumkin toy
Quote from: GreenYoterKrawler on April 08, 2011, 04:37:15 PM
then do it!  this thread is obviously for people who like to tow and want to discuss the benefits of different tow rigs.
97 4runner Limited
Tofudude
i'd rather drop 10 grand to make my toyota tow another toyota...o snap!
i'm just being a dumb arse  :hammerhead:
ROCKO
01 F-250 7.3
we well see how good it does this weekend going to the rubicon!!!
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
howyadoin
That's fine...as long as you stick to the bunny slopes I suppose. ::)
"Flexes like a boneless hooker on muscle relaxers"
ToyMan86
93 Ford crew cab, swapped the 460 for a 7.3turbo diesel with ats junk under the hood. runs good and tows okay. wish it was a powerstroke! but theres nothin like wheelin hard and riding back home knowing your wheel isnt going to come off at 70 haha
94 ****, needed something for the future ex
89 4-runner with low low miles
12 valve
Old rig 04 6speed 4x4.
12 valve
My older truck new tow rig. 96 12valve 5 speed 4x4 price was right.
dzldust
1997 Ford F350,4x4,crewcab long bed ,auto with 7.3PSD
why?simple ,reliable,plentiful parts and if anybody needs a spare D60 I got one....
JMScrambler
97 Ford F350 4x4 w/7.3PSD and auto. Because it is reliable and paid for!
I tow with my Toyota because that's all I have........
boggerunner
sold my 2000 f350 powerjoke and picked up an 03 chevy duramax cause it starts without being plugged in
mudmaster
2004 F350, 6.0. cuz it has no problem towing my junk.
Time to go wheelin!
