Author Topic: differential question?  (Read 2723 times)
jpmxer
  • Member since Jan '08
« on: Feb 11, 2008, 06:15:06 PM »
on my 4 runner i noticed the driveshaft turns almost a half of a turn before it engages. what causes this?
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
Re: differential question?
« Reply #1 on: Feb 11, 2008, 07:49:55 PM »
do you have a detroit in it, is it factory or what?
93tonkatoy
  • Male Posts: 463
  • Member since Jul '07
« Reply #2 on: Feb 11, 2008, 10:02:55 PM »
It all depends. are you referring to the front or rear? if the front, do you have add or auto locking hubs? If it's the rear, do you hear "gear whine" varying with your speed on the road? With a little more info, it would be easier to pick out the problem. Year, axle, setup (gear ratio, stock/ aftermarket), open diff/ locker (type) would help.
SAVE TELLICO post 491
« Reply #3 on: Feb 12, 2008, 06:32:54 AM »
sounds  like extremely bad  contact pattern/backlash
jpmxer [OP]
« Reply #4 on: Feb 12, 2008, 07:06:38 AM »
this is in the rear diff. i have 529's with a detroit. i do hear some whining but i thought that was coming from the transmission.
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #5 on: Feb 12, 2008, 07:32:03 AM »
its the detroit.  everyone i know with a detroit has that.  try parking on a hill, when you let the clutch out with no ebrake, it will roll back like a foot.
jpmxer [OP]
« Reply #6 on: Feb 12, 2008, 07:50:13 AM »
exactly. that is how i noticed it. no big deal then?
Fearofrunner
  • Male Posts: 620
  • HOW AN 84 SHOULD LOOK
« Reply #7 on: Feb 12, 2008, 07:59:43 AM »
I think it's the 5.29s, i've got an aussie and it does the same thing. Even with the t-case e-brake on it rolls forward/backards a bit.
« Reply #8 on: Feb 12, 2008, 11:50:28 AM »
:eek:  who set up yalls  differentials  :eek:
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #9 on: Feb 12, 2008, 11:54:11 AM »
Mine doesnt...its tight like a tiger...
Fontucky Fab! They had a two-fer deal :yupyup:
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
« Reply #10 on: Feb 12, 2008, 11:59:15 AM »
haha! yeah, shouldnt do that....... excessive BACKLASH
« Reply #11 on: Feb 12, 2008, 12:27:48 PM »
i set my own up  with .006  of backlash  and  my pinion  doesnt move maybe 10 degrees,  if that
Fearofrunner
  • Male Posts: 620
« Reply #12 on: Feb 12, 2008, 01:44:52 PM »
ya but you got 4.37 gears, the guy that did my gears had his dad and the other owner of their diesel shop (that do alot of gears for big rigs and small rigs) look over his work and said it was excellent.  The yellow marking grease showed good and even lines across the ring.  I've also beat on these gears and DD my truck and it's as smooth and as quite as it was with the factory set 4.10s.
Just my two cents YALL...
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #13 on: Feb 12, 2008, 02:13:43 PM »
I set up my own.  I had .007" backlash, but the detroit makes it act like that.  There are several pro setup diffs around here I know of that are the same as mine.
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #14 on: Feb 13, 2008, 10:11:19 AM »
must be the detroit
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« Reply #15 on: Feb 13, 2008, 01:40:35 PM »
thats a relief. i have 5.29s with a detroit and it does that too. never really worried about though cuz there were no other problems with it
UA 342
STEAMFITTERS
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #16 on: Feb 13, 2008, 03:02:57 PM »
Its the Detroit for sure.
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #17 on: Feb 14, 2008, 09:22:14 AM »
i havent ever ran a detroit....i'd like to though!! only lockrite and lincoln
mountain28
« Reply #18 on: Feb 15, 2008, 03:53:20 PM »
i have the same problem but mine is stock with 355,000, is that bad gears? i drive it every day and it will snach in any gear.
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #19 on: Feb 19, 2008, 08:44:56 AM »
snach in any gear???
skyscraper
  • Male Posts: 589
  • Member since Jan '07
« Reply #20 on: Feb 19, 2008, 12:38:55 PM »
In the setup manual for the aussie, it states that "excessive backlash is normal for these types of lockers"
Its the locker not the gears.
bluetoy84
  • Turtle Points: -100
  • Male Posts: 300
  • Member since Jun '04
  • rice bouncer
« Reply #21 on: Feb 20, 2008, 11:54:27 AM »
Agreed. Detroits (and lunchbox lockers) have excessive backlash. I like them for a front diff, but too much slop for a rear.
I've always ran welded rear diffs, but I traded for a detroit and swapped it in my rear diff. After about two months I put my welded diff back in because I did not like all the slop in the detoit. Seems to me that the extra backlash would be harder on the gears and shafts. When you roll back on a hill and dump the clutch the backlash allows the shaft to slip enough for it to ramp up to speed and then engage violently.
I'll stick with my welded diff in the rear and leave the detroit for a front. Just my $.02.
TOYOTA FOUR WHEEL DRIVE..............need I say more?
  • Male Posts: 7,110
« Reply #22 on: Feb 20, 2008, 12:04:33 PM »
If they are set up right backlash is negligible  :yesnod:
bluetoy84
  • Male Posts: 300
  • rice bouncer
« Reply #23 on: Feb 20, 2008, 12:26:00 PM »
You must be referring to a lunchbox locker (lock-right,aussie,etc.)  :headscratch:
The backlash I was referring to is internal on a detroit (full case) locker. If there is a "correct" way to set up a detroit please explain. :dunno:
skyscraper
  • Male Posts: 589
« Reply #24 on: Feb 20, 2008, 08:41:18 PM »
He is not talking about backlash on the gears.   Thats different then the backlash in the locker.  I can turn my aussie inside the carrier a good 1/8 turn or so.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #25 on: Feb 20, 2008, 08:56:50 PM »
My Detroit did have some excessive backlash in it too, it was professionally setup. My welded diff didn't have this so I vote for the locker, if I remember correctly it also stated this issue in the instructions/owners manual.
skyscraper
  • Male Posts: 589
« Reply #26 on: Feb 20, 2008, 09:25:06 PM »
I measured mine and it is what its supposed to be(6-10 thou or something, dont remember).  I can actually move the locker inside with my hand.
Last post Jun 05, 2005, 09:05:37 PM
by Duffil
Last post Jun 05, 2005, 10:21:27 PM
by KYOTA
Last post May 10, 2007, 08:10:24 AM
by Panama85
Last post Aug 25, 2007, 12:24:30 PM
by klmmicro
Last post Dec 14, 2009, 12:22:14 AM
by NorCalToy
