The beauty and the beast
Started by Colt, February 07, 2008, 12:50:10 AM
Colt
today I installed the heating valve
3mm plate of aluminum
junkyard shopping: the valve comes out of an nearly new Honda.
I will add an return spring when I find one...  :cheese: And the hoses will be connected when I put the new radiator in.
on to the inside
I made an mockup out of cardboard
and the final piece out of 3mm aluminum plate
thats all for this weekend, tomorrow we went for short trip to my parents-in-law... ;)
twistedtoy92
Colt
I still had a few things to do but too short with time...
AND I got a servo steering!
steering pump
expansion reservoir
got the used hydraulic lines from an friend from austria
i had to cut them to the right length and flange the lines to make em fit.
but then they line up perfect!
next will be putting oil in and an fitting v-belt on. Maybe next week-end...  :yesnod:
after that I will fit in one of the cb-radios I received as a gift...
Colt
Oh, I forgott: last month I bought an trailer...
nice combination....  :greengrin:
Colt
I added a jerry can holder
painted it black and back on the beast
and made a bracket for the cb-antenna out of scrap metal
twistedtoy92
unclejpl4x4
mm the wheels on that trailer are a little on the small side
the :moon: of your truck is hott  :hitit:
Colt
 :shake_head: i missed the last answers!  Sorry!!!
@tt
thank you!
@ÜncleĴ
these tires are for heavy load at higher speed (100km/h) plus you could get a low platform height.
Colt
The last progress I made:
took out the radiator because I need the space. The reason will follow later... ;)
but driving around without radiator isn`t a real good idea. Pipe made of cooper and some epdm fittings:
under the cabin
to the wooden deck
to the radiator on the deck
the radiator is out of an VW VR6 with nearly 300HP. It should provide enough cooling. 8)
with an self-made fan shroud
this fan has 250watt on the high level and 60 on low
self made t-fitting with expansion tank out of an VW.
and back to the engine with the cool water ;)
and now the reason of this build:
-the cooler doesn`t get dirty while diving through mud pits
-theres enough space in the engine bay for the winch and a second batterie:
red is the place for the second batt and yellow for the winch
hope i could post more progress tomorrow  :crossed:
unclejpl4x4
Colt
Not much progress because we changed the axles on a friends truck.
the donor truck
the frame and body are scrap because of rust but the rest is super!
his snowlux:
old 1:4.11 to new 1:4.56
we "simply" changed the axles so nothing adjustment needed to the diff!
but back to the beast:
i forgot something to get the air out of the engine. I cut a piece of copper down and drilled a hole to fitt in a brazen hex-nut.
After that i soldered the nut in:
I widened the ends of the pipe with a modified molegrip
the pipe end have to be annealed. nothing spectacular, just get it hot until its like a cherry ;) once the temperature is reached it will stay soft even it is chilled down.
getting the pipe in and tested:
the engine don`t run on this picture!
Colt
To get it street legal i had to cover the tire tread.
I will ad some rubber flaps so i don`t get turned over on every trip...  :shakehead:
But on to the nicer things:
cutting out the cross-beam
now its enough space for the winch  :biggthumpup:
the old winch mount is out of my 3rd gen pickup. It have to be cut down to make it fit.
I want to keep the original bumper simply cause i like the look!
took out some sheet metal
tagged it in
welded it completely in and grinded it smoth
NotSoPC
I like the way the stock style bumpers look with the winch behind them :thumbs:. Good looking truck  :beerchug:
87 Sammy
YJ's, Toy axles, 6.5 t-case, 33" SSR's
B.F.I. eng.
Colt
@NotSoPC
Thank you. The pulley only sticks out 5mm
Today I completed the winch mount and the bumper.
winch mount ready welded, painted
and on the beast
I don`t now where the missing pulley ist...
The top of the bumper needs to be cut out to clear the wire while pulling out of wholes.
tack welded
completely welded and smothened
and finished:
the wire rope and all the electric things are still missing but i`m afraid i haven`t the time to do that this week.
hope i finish it next week...  :crossed:
Colt
 sorry for the long time without update...  :-\
added an fan guard
I fixed the wiring but I decided to keep the wiring simple and not to use the second switching stage.
the relay needed a cover because I cracked the first relay by standing on it  :hammer: Not a real big deal but out on the trails real annoying...
finished the fender flares
Colt
and yesterday I emblazed the beast with flower arrangement:
and now we are married!
locked 4x4
What a great build   congradulations
twistedtoy92
