if it was bad, how would your truck run?
it is on the pass side of the motor near the firewall and it recirculates spent exhaust gases back into the intake stream in an attempt to make some of the nasty stuff get reburned for better tailpipe emissions
If your truck drops a bit below idle like you said when letting completely off the throttle then you may have a dashpot issue as well.
That's actually not why it's there. It is there to lower combustion temps to reduce NOX emissions. Exhaust gas is inert and does not burn. A nonburnable gas in the cylinder means slightly less air and fuel to burn which creates less heat during the burn. The amount which flows through the EGR is minimal and reburning what is still burnable in the exhaust gas is not worth the trouble of doing so.
Started by Sparkplug General 4WD Discussion
Started by Shamb Toyota Pickup/4Runner Tech 1979-95
Started by Jakesteads Engine
Started by Johnny5 Toyota Pickup/4Runner Tech 1979-95
Started by chevyLUVtoyota Engine
