salmon died, now the smolt emerges from the gravel
Started by Ramrod, January 03, 2008, 05:21:43 PM
kiyul4130
isnt your pile of :pokinit: sitting right next to his? check your motor! i know there different years but some of the stuffs got to be similar.
-kiyul-
ECV 7-11
KYOTA FOREVER
Sluice Box Hero
Neutral saftey switch for the auto. But since you are getting it to crank...... I don't know, but I bet it has to do with those plugs.
"You know that feeling right after you take a huge dump? . . . . Awesome"
-Cartman
Ramrod
pete just got a taco that is the same year and we figured out what all those on the one chain were and unplugged them all and the truck still runs fine, then we swapped computers and his truck ran on that also, the other plug is the alternator wires.  If you look at the picture of all the plugs you'll see that there is a blue jumper in there, that is the nuetral safety switch wire.  The circut opening relay is kinda shotty and loose so im gonna throw one of those in there that I have and see what happens.  After that I dont know where to go
rockwalker
85 runner with 3RZ  linked  locked  and ready  2rock
http://board.marlincrawler.com/index.php?topic=40729.0
87 tintop..........................................................
Sluice Box Hero
Hmm, is it getting spark? Is it getting fuel? Is the afm attached properly? What exactly is of doing when you turn of over?  You might want to check the rail for pressure. Also is the cps connected? If so did you mod the harness between that and the coils?
-Cartman
Ramrod
it has the ors harness, there is seriosly nothing to connect or disconnect.  It doesnt get spark or fuel.  we have been jumping the fuel pump from the battery so we know the rail has fuel.  ORS is out of business and there phone number is disconnected which makes this harness and any problems to do with FUCKED
kiyul4130
i doubt there harness is bad. its something really small and stupid.
-kiyul-
ECV 7-11
KYOTA FOREVER
Doof
post it up on pirate.... im sure somebody over there will know whats up
Ramrod
fucked with it for a while today and then got over it and started on the exo
Ramrod
so we've swapped computers, swapped circut opening relays, checked all ground, computer is getting power, traced all unplugged plugs, and she still is dead
Duffil
well it is OBD II...have you hooked it up to check for a code?
Ramrod
will it throw a code if it isnt doing :pokinit:?  it doesnt spark or start the fuel pump
Duffil
yeah it oughta show something. at least a fault.
Ramrod
ill round up one  of those then tomorrow and try it out
rockwalker
rockwalker
since can't get the motor running played with the shocks in the rear filled them up with the most oil i could put in, they are nice now.  NEED BIG MIKE'S HELP with motor
TheCookieMonster
are you sure all the wiring is connected correctly ?? seems like a power issue to me  :dunno:
Ramrod
there is nothing to incorrectly connect, they all connect to only certain plugs.  we believe ors left out the entire circut  and efi relay
TheCookieMonster
ok..i forgot its an ORS harness. that could be possible they left those out. have you guys checked all the fuses?? im sure its something simple, just a pain in the ass to figure out
Ramrod
all the fuses are perfect, looking at ohioyotas buildup who has the same year of both harness he has 2 ors relays, this harness has one.  to make it almost impossible to fix the ors harness only has yellow and black and white wires and about 30 of each all of which are wrapped up super tight so you cant tell where any are going or coming from or what they are doing
Ramrod
this thing might not run but it still flex's like a champ
the flex from the rear is pretty silly actually
John Doe
pumkin toy
holy crap dude!!  i think you got plenty of articulation!!
97 4runner Limited
TURBO
gotta love the TOYOTA forlkift lifting the TOYOTA....
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
DTB
rockwalker
#177
TO BAD THE RUNNER WON'T START UP
rockwalker
got the Toyota forklift back up and running it had a bad alternator and air in the lines.  its a big help to have it back up and running
BigBs84
Build it wright-wind it tight
   High-N-Tight offroad
http://board.marlincrawler.com/index.php?topic=45027.0 My truggy build
