salmon died, now the smolt emerges from the gravel
Started by Ramrod, January 03, 2008, 05:21:43 PM
Jud
"bout tree fiddy"
pumkin toy
Quote from: rockwalker on July 24, 2010, 05:22:22 PM
not watching where I was going. I knew I was not going to make the turn, but my front pass tire fell down in the hole, and started going over before I could done anything to save it.  I was going to cut the front off anyways just didn't want to cut a clean clip for no reason.
ha ha  so you werent really wheelin?  just cruisin around the corner and dropped the tire off the edge huh?
97 4runner Limited
rockwalker
85 runner with 3RZ  linked  locked  and ready  2rock
http://board.marlincrawler.com/index.php?topic=40729.0
87 tintop..........................................................
rockwalker
a little update got front fender and hood back to normal from the roll and been finishing up the rest of the cage
pumkin toy
97 4runner Limited
NITE KRAWLERS
Nice flex pics bro.. I can't wait to be flexing like that man!!
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
95toyrunner
Where did you get your rear swaybar or did you make it? Do you have any good shots of the histeer you fabbed up for that thing?
1995 toyota 4runner, sr5, 5" sas, ome 863 coils, extended links, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=51430.0 SOLD
1996 Toyota Tacoma ex-2wd, 2rz, 3link 14"FOAs, dual ultimate cases, chevy rear, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=91724.0 SOLD
2001 Taco Dcab, king coilovers, 4.56 gears, detroit, 33's, SOLD
1999 Taco extracab, 3.4 5 speed, sas'd on one tons, 37" km2's, spooled front, detroit rear, bobbed, tirecarrier, hydro asist, high steer. SOLD
2005 4runner, sway-a-way coilovers, all pro rear 3.5 springs, 285 ko2's on method NVs SOLD
2016 4unner Trail, Icon stage 6, 285/75 Toyo's, full armor
88 4runner SAS, 37's, duals, etc
95toyrunner
#337
Oh and which TRE's you runnin? And what's the zelda sword?...I don't get it  :dunno:
rockwalker
GM 1 ton ends the zelda sword is my pitman arm its
Sway bar is Rock Equipment or TK1racing.com same place I got my air/coilovers shocks
twistedtoy92
09roramo
this build is sick. axles look really strong. flex is crazy too.
'84 toyota pickup 4x4
22r, 38 weber, 261C cam, headers
4" all pro springs, 5.5" shackles
4:88 gears with e-locker in rear
2001 Dbl cab tacoma 4wd
5 speed conversion
Pavement pounder
CrawlerBrennan
Lets go camping
95toyrunner
Quote from: rockwalker on November 03, 2010, 07:31:34 PM
GM 1 ton ends
do you know the part number? im going to build the same type of steering so any info you can give would be great. like tread pattern, length of tierod and drag link...whatever thanks
rockwalker
little update had RUFFSTUFF build me a new rear axle its a 9.5" lc :flamer:
I also Got a pair a 14" Bilstein coilovers for the rear.  They are about 4" longer than the 14" air shocks that I have in there right now so I need to make some big changes like a new rear frame with taller shock hoops and some other mods  :stopit:
Jud
Quote from: rockwalker on December 23, 2010, 10:12:25 AM
What do you want for the air shocks?
"bout tree fiddy"
rockwalker
I don't know maybe $550 there 2.5" and two trips on them
