salmon died, now the smolt emerges from the gravel
Started by Ramrod, January 03, 2008, 05:21:43 PM
0 Members and 10 Guests are viewing this topic.
kiyul4130
the old salmon lookin like it use to. hey what are you strapping the back and front at? looks like the beginnings of a cage on that thing.
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
yota_krawler
thats a cool runner, I dont know how I havnt seen this thing yet.
twistedtoy92
rockwalker
so after a lot of bad noise i finally got my 3rz to do something i called mike from ors and we talked for about 2 hours going over everything and checking for power.  It turned out to be a efi relay from the 85 wasn't in at all put it and got it to run but it had a check engine light.  checked the codes plugged in a sensor on the back of the motor and it was golden it runs great.  big thanks to mike
85 runner with 3RZ  linked  locked  and ready  2rock
http://board.marlincrawler.com/index.php?topic=40729.0
87 tintop..........................................................
pumkin toy
awesome! glad you finally got it running. so what is left to do before you can wheel it?
97 4runner Limited
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
rockwalker
here you go
Exhaust
sway bar in back
EXO
PSC steering still waiting for it
all fluids, gear oil everywhere
finish triple shifter
bump stops
wiring check
fender cuts
bob welding
DMV crap
Bolt check everywhere
and a lot more
bigarms23
for the exhaust can i recommend a magnaflow converter to a flowmaster 40 that combo sounds great
rockwalker
got my psc steering today and put it on :beerchug:, also got sway bar for the rear just need arms from KIYUL so i can get down on that.  Its going in to the exhaust shop tomorrow.
peacesells
this my man lysol, fresh out the joint
Sluice Box Hero
"You know that feeling right after you take a huge dump? . . . . Awesome"
-Cartman
Ramrod
he just towed it to get the exhaust built, im sure he'll be playing around later
rockwalker
the salmon maybe getting some 40" Creepy crawler hopeful
rockwalker
got the creepys they are sick, also a new radiator and shroud put in.  I patched the hole in the floor where the link comes inside.  Took it on a test ride down the road but i didn't want to go to far with out a temp gauge,  but it drove good for only having 3 lug nuts per wheel and loose bolts on the shocks.
boggerunner
Ramrod
there is one of his tires next to a "40" irok
rockwalker
getting close for its trip down to the hammers hopeful i will have these tires on rims to bring to the hammers.  I have a lot of stuff to bust out before then.
lilbuddy
Quote from: rockwalker on April 13, 2009, 11:34:28 PM
you better get it done man
RIP Kyota.... you are the man
GET IT!!!
YODAWILL
Those Creepys are sick can't wait to see them on the salmon.
kiyul4130
where you been hiding out will? whats goin on with the sonoma scene, you guys need to get your rigs out wheeling this summer.
-kiyul-
ECV 7-11
KYOTA FOREVER
Ramrod
theyll be out there, ill will picked up his new rears today.  salmon is riding dirty like a cadi
YODAWILL
No Hiding just school, I will be out there this summer went a checked out the salmon yesterday its looking sick.
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
rockwalker
got sway bar in and flexed it out it works good.  tomorrow its getting side bars and welding on sliders fully, fix the return line and finish up wiring need to wire up Elocker and a lot of little things that suck to do right now just want to drive it
yota_krawler
rockwalker
did you fix the motor problem?  how did it run the rest of the way home from the hammers?
rockwalker
i think it might be the timing chain, i compression tested it and it had 180 on all four,  going to bring it somewhere tomorrow.
