0 Members and 8 Guests are viewing this topic.
how does it pull, slow are at high way speeds. What about hills?
Some shops around here take the stock 22r/re manifold and cut off the 3 bolt flange. Then weld on a custom fitting with larger piping. a kind of homemade header. I shoulda tried that b/f the getting the LC header.....
I'd like to see a picture of that too. i've got a spare 22r pipe and i'd like to try that before spending more $$ on a header.
no 2 1/4 is what most people upgrade to, ive seen some with 2 1/2 but that doesnt leave enough back pressure IMO
does anyone know what the stock weight is for fly wheel?
i have a 89 with almost 200k and with a cam thorly hedder 2.25 exhaust 4.56 gears 35" bgs i can run 75 up most of the hills here in 4th dumping 3rd only when passing and still get 20mpg
hey tonyas dad has some 35 bfg's he can sell you!! i knew it had to be your cat!!! that thing will run like a striped ape when you fix it, i just got back from bottle hill its snowin good there, tomorrow im not working if you wanna adjust your steering, also id go with the 2 1/4 but thats just me........
I found a 30 lb flywheel on summit and was thinking that it has to be heavier than stock. LCE has a 35 but you have to use thier clutch and I just got a clutch. So a heavy flywheel would help Right
I was thinking that all the bolt ons and mods I am doing will improve top end, I want to increase bottom end as well so heavy fly wheel is what I came up with
a 22R doesnt need help in the low end department, they DO need help in the over 3500 departmentfyi my previous motor, a 20/22 hybrid(with the same cam i have now) pulled (in gear going down the road) out to 7000 rpm
You can find Ford Taurus fans at pick yards for pretty cheap.That's the really strong electric fan right?
WOW 7000 rpm! does the stage 2 cam let you spin it up that high? I've heard that toyota sets a really low redline on their motors (all the internal stuff is built to handle more rpms but the cam sets it's redline... floating valves and what not). Does LC say the cam will let it spin up that high without problems glen?
Started by Boomez Engine
Started by wolffman Toyota Pickup/4Runner Tech 1979-95
Started by 79coyotefrg Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by yota_krawler Tow Rig and Trailers
Started by *FFC* Chit Chat Camp
