get oem. 50% of parts stores alternaors are crap off the shelf
Are the bearings bad or does it just not produce? I got replacement brushes through toyota for less than $20 I think, and it was super easy to do. The hardest part was pulling the alternator.
I'm not really sure what the problem is other than I suspect the alternator. The batt light has been coming on, yesterday it started staying on nearly 100% of the time and it is obvious that it is running on the battery since the wipers and rear window are getting slower. I made sure to get home before I need lights.
Having run an autlite alt I can only say RUUUUUNNNNN!!!! Mine fried itself and took out the alt harness with it.
Not to hijack the thread, but what about having alternator rebuild, with higher out-put? Looking for like 90-120amps? Anyone have any experience with this?Erik
HiJack away.I just finished installing the NAPA alternator. The 70 amp one was for the auto trans and I didn't want to mess with it.
So what do you recommend out of the original list? I'll be back to a 60 amp.
and what was ment by hijack away
If it were me I'd be comfortable with the denso (often what toyota uses), bosch or beck arnley, in that order.
I think the NAPA was a beck arnley.
I guess you have a 50/50 chance that it will be a bad alt
This is a good question. When mine went bad in my '84 I relaced it with a 130 amp GM unit since upgraded parts for the Toy unit were not available And probably are still not...are these parts available for later model units? You'll have to ask the rebuilder. I've known the guy, who builds all my stuff, for a lot of years. He's a rebuilder and has been for many years. A good quality rebuilder should know this stuff. Ask around...
Hmm a GM alternator. I've heard rumors of doing this, what does it take? I'd imagine you'd need an internally regulated alt, and probably have to modify the mounting bracket. Any other wisdom you could share? I'd be likley to try this if its really feasable.Thanks
Started by jb1981 Toyota Pickup/4Runner Tech 1979-95
Started by Opias Toyota Pickup/4Runner Tech 1979-95
Started by motoracer Toyota Pickup/4Runner Tech 1979-95
Started by Wainiha Engine
Started by 80farmyota Toyota Pickup/4Runner Tech 1979-95
