Author Topic: help quick no brakes  (Read 2385 times)
robrub00
  • Turtle Points: -231
  • Male Posts: 929
  • Member since Apr '05
  • One Day Ill be actually driving my toyota!
« on: Oct 14, 2007, 06:05:59 PM »
i tried bleeding my brakes 3 times.  the rears dont bleed.  i pump and hold.  turn bleed valve and the pedal dosent move and nothing come out air or fluid and the pedal stays stiff.  the front do.  then when pumping brake pedal fluid looks like it is coming up from the bottom of the cup.
is my master or  booster bad????
  truck was sitting a year with out moving with the brake lines disconnected( dont ask me why)
Mistaken
  • Male Posts: 55
  • Member since Oct '07
  • i like lights
Re: help quick no brakes
« Reply #1 on: Oct 14, 2007, 06:13:54 PM »
how do the shoes look compared to the pads? if the pedal doesn't drop when you crack the bleeders then most likely you have a blocked or collapsed line. also remove the bleeders completely from the wheel cylinders and clean the bleeders out with a small drill bit. i have seen them rust shut when people loose the rubber boots that go over them.
1997 gmc sierra short box 4x4
33"mastercraft MT's
cat back duals
« Reply #2 on: Oct 14, 2007, 06:15:04 PM »
no,  you have lift  but didnt raise the  lever thats attached to the  rear axle did you :slap:
take  that rod loose  from the axle  and tie it with a zip tie  up to the frame rail or crossmember,  this will give 100%  brake pressure to the rear brakes,  then you can  bleed them
i keep mine  like that
« Reply #3 on: Oct 14, 2007, 06:16:31 PM »
while this is  very true,  do  what i suggested first
the LSPV  must be raised  if  you have a lift  or it will not send any brake fluid  to the rear drums
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
« Reply #4 on: Oct 14, 2007, 06:17:19 PM »
try gravity bleeding it.   and tie the LSPV arm all the way up.
Mistaken
  • Male Posts: 55
  • i like lights
« Reply #5 on: Oct 14, 2007, 06:29:46 PM »
LSPV :dunno: sorry kinda toyota illiterate
33"mastercraft MT's
cat back duals
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #6 on: Oct 14, 2007, 06:31:14 PM »
Load Sensing Proportioning Valve.
« Reply #7 on: Oct 14, 2007, 06:34:38 PM »
its  the  load sensing proportioning valve
the more weight thats in the truck brings the bed/frame closerto the axle  making it  need more rear brakes,  so  if  you lift the truck and dont lift the arm  it  doesnt apply ANY brakes  to the rear
Mistaken
  • Male Posts: 55
  • i like lights
« Reply #8 on: Oct 14, 2007, 06:37:37 PM »
 :smack: i knew that, the abbreviation just didn't make sense for some reason.
33"mastercraft MT's
cat back duals
robrub00 [OP]
  • Male Posts: 929
« Reply #9 on: Oct 14, 2007, 06:50:03 PM »
it appeared to bleed fine the first time. I lifted the lpv rod all the way up and no luck. I also have a lift for that bracket installed
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #10 on: Oct 14, 2007, 06:59:48 PM »
rod tied to frame. truck parked front to street in driveway with slight slope. trying gravity bleed but doesnt seem to do anything
robrub00 [OP]
  • Male Posts: 929
« Reply #11 on: Oct 14, 2007, 07:04:56 PM »
yeah what jimbo said.
« Reply #12 on: Oct 14, 2007, 07:43:23 PM »
you either have a blockage in the LSPV  or  you have a  smashed line,
take the line from the front of the truck loose  where it goes into the LSPV  and see if you have juice there,  if you do  you can bend it down some and hook your rubber line  that goes to the axle directly to it,  thats how i have mine
robrub00 [OP]
  • Male Posts: 929
« Reply #13 on: Oct 14, 2007, 08:35:50 PM »
i have a spare lpsv  id rather swap it but i cheack and see tommarow
Last post Feb 20, 2005, 07:13:31 PM
by trollbum
Brakes
Last post Aug 05, 2005, 07:22:17 AM
by *FFC*
Last post Oct 11, 2005, 03:04:55 PM
by S-10 Stewy
Last post Dec 19, 2005, 09:45:01 PM
by gmrwizard
Last post Mar 15, 2006, 05:38:00 PM
by toyzuki
