Author Topic: hard braking  (Read 1995 times)
4rox
  • Turtle Points: 115
  • Male Posts: 122
  • Member since Apr '04
  • Crawling in texas
hard braking
« on: May 12, 2004, 04:03:55 PM »
I have a 94 ext cab. Its mods include sas,350,ford 9inch.I've recently replaced both rear wheel cylinders,rear brake shoes,master cylinder.The truck stops okay yet the pedal is as hard as when the engine is not running.The engine is a 350 bored .030 over with a healthy cam.Could the cam be part of my problem?What do I do????
I'd rather push a Toyota than drive a Jeep!!!
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • yellow beast
Re: hard braking
« Reply #1 on: May 12, 2004, 04:12:53 PM »
the pedal is hard because the engine is not running.  the booster needs to engine to be running to, well, boost the brakes.
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: hard braking
« Reply #2 on: May 12, 2004, 04:38:15 PM »
if there is no diff. beteew the eng. running and not running then its the booster, or the vac line to the booster. the big cam will weaken the "boost" at idle but coming up to a stop sign it sould not matter.  chek for vac to the booster and leaks at the booster, I use carb. cleaner with the eng. running.   good luck :thumbs:
kyle_22r
  • Male Posts: 1,233
  • yellow beast
Re: hard braking
« Reply #3 on: May 12, 2004, 06:41:26 PM »
ah man, my wisecrack backfired on me :smack: i need to get some reading comprehension
WHITE_TRASH
  • Turtle Points: 679
  • Member since Feb '03
Re: hard braking
« Reply #4 on: May 12, 2004, 06:56:39 PM »
Yup a big cam will not draw enough vacuum for you power brakes.  Id suggest a vacuum can from summit they're cheap and they will work well for what you need.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: hard braking
« Reply #5 on: May 15, 2004, 10:05:09 PM »
If your truck has a rear load porportional valve, it may be rusted up. Put the rear end up in the air, push the brake pedal, and check to see the rear brakes are working.
Marlin
« Last Edit: May 15, 2004, 10:07:58 PM by Marlin »
Last post Dec 02, 2005, 08:43:04 PM
by rockscrambler
Last post Apr 04, 2006, 07:54:48 PM
by MudSlinginYota
Last post Sep 24, 2007, 06:44:22 PM
by lilbuddy
Last post Sep 24, 2008, 09:40:11 PM
by DFWFO
Last post Feb 05, 2024, 08:40:49 PM
by Shamb
