The Eighty-Sixed Runner
Started by Doof, September 27, 2007, 08:22:00 PM
whats the next step
keep the runner
2nd gen extra cab/first gen bed
46&2
Quote from: silly58willy on November 11, 2007, 01:01:31 AM
tomorrow i need to rig up an extended break like for the rear connector at the T on the axle. i know how to do it its just a matter of getting it done. then im going to bleed the system and test it out. hopefully that works. the calipers ive never cleaned in my life...what do i do with that...take the pads off and spray break cleaner in them or what??
Well I would inspect them to make sure they need to be cleaned first. Mine NEEDED it badly because I had a nasty gear oil/grease leak. If they arent all gunked up and dirty I would just leave em be.
KDXSR5
DTB
wake up slacker!
its daylight in the swamps! :whip:
(my dad used to say that to get me out of bed)
Doof
#213
Quote from: KDXSR5 on November 11, 2007, 11:06:10 AM
Where are you mounting your firestik? I don't know if you have already specified this, but I was just wondering.
my buddy matt mounted it on the rear of his shell and it was a good spot so im gunna mount mine there as well
when i get it done ill take a pic
edit:
so today  woke up around 1030 and got right to work. i have a :pokinit: ton of pics to post from yesterday and today. so it will be a while becuase i still need to send them from my phone to my email and then photobucket them and then post them here....but it will be done today
NorCalToy
you tell us about pics but you dont have em ready to post yet? shame on you  :tantrum: . actually that sounds like something i did too  :yupyup:
:flamer: IFS
lilbuddy
Quote from: silly58willy on November 11, 2007, 05:28:22 PM
You bum... Get to it. Dont forget to put that one pic up that I took and DONT FORGET to tell that I took it :yupyup:
Oh and i have a neat suprise for you.. ill PM you
RIP Kyota.... you are the man
GET IT!!!
Doof
#216
here are some pics...i only got this one from my lap top... i need to use the desktop and get the rest of the pics
but here ya go... they my rear spring hangers i made out of 3.5"x3.5"x.25" wall and they are on the springs right here
KDXSR5
What length is the firestik? Is it one of those adjustable ones (firestik II)? Tell us how it works out once you get it all done and can test it! Nice hangers!
Doof
Quote from: KDXSR5 on November 11, 2007, 06:19:31 PM
i havent bought it yet.. but im gunna get a 2 or 3' foot one
thanks
here is part of the front DL. my buddy matt did some welding on it while i was working on the truck outside. and this is how he cleaned it up. this pic doesnt do his work justice. it is really realy nice, but i cant use it.. more on that to come
Doof
while matt was working on the DL i set up my workshop outside. it was raining but i made it work. it was pretty nice.
then later on at night i put on my DL and this is how it turned out. i just put on the CV joint... for more info on the useless new front DL read this http://board.marlincrawler.com/index.php?topic=38897.0 and then look at this pic. in the second one you can see why i cant use the CV anymore
Doof
i didnt take much pics yesterday but i got a few today. pic one is my shackle angle after mounting and welding the hangers to the frame. its hard to see but if you look close enough you can see that the top right part of the shackle isnt touching anything while the top left is under the frame rail. that pushed the bottom of the shackle out to the right about an inch. in the second pic you can see how the little plate took care of that
Doof
backtrack a little bit for a lil info on the next few topics
i only swapped out one spring becuase of the rain at the time. so after i got the spring swapped out i drove the bomber back through the yard to the garage where i backed it. when i backed in we disconnected the rear breaks so when we jacked the body up it wouldnt pull the lines. so i had ZERO breaks. we got the other spring swapped out in about 1/4 of the time since we both knew what to do right. after we got the spring swapped out i pulled out of the garage and turned around in my street. i forgot i had no breaks and went to hit the breaks before i rolled into my neighbors mail box. i didnt stop but i pulled the ebreak and stopped. then i turned around and pulled back into the garage for some last minute touch ups. we got done working at around 1230. then i sat in my hot tub for two hours and almost fell asleep a few times. i dozed off once but woke up. and by the time i went to bed it was 3am. so when i woke up, matt came over and we fixed the shackle angle. last night we were to tired to figure out why it was / so we jst said F it and went out seperate ways. but when i woke up we got that taken care of first. then we extended the break line to help compensate for flex and what not. i put the shocks on and then drove to lil buddys. we went out to the airport and took some poser shots. but keep in mind, the front sprigns are still BRAND NEW and this was the first time any pressure was applied to them. and this is what is looksl like. then i backed around and the rear springs are amazing. when i put on my 1.5" wheel spacers up front it will look better as well. but anyways enough rabeling and more pics....
and then you have lil buddys pic
DTB
NorCalToy
:flamer: IFS
Doof
it was chris's and it got crushed flatter then flat when i took off
46&2
MiniSimp
Quote from: silly58willy on November 11, 2007, 07:32:36 PM
Note to self; Mt. Dew cans make bad wheel chocks. :gap:
NorCalToy
:flamer: IFS
Doof
does anybody know if a V6 master cyl. will work on my 86 4cyl?
46&2
Yes it is a direct bolt up. Marlin sells brand new ones if you need one.
Goose
Lookin good man.
Just got my SAS done, check out the buildup thread.
So are you runnin without wheelspacers up front?
With my v6 calipers we had clearance problems, so i used some dinky lil 1/4" spacers for now.
And yeah, Mt. Dew Cans do make good substitutes for an E-brake
40' bottles on the other hand.... :gap:
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
lilbuddy
Quote from: silly58willy on November 12, 2007, 03:15:50 PM
Yes
There are A LOT of master cylinders that bolt up. Mine is a 15/16 bore toyota cresidda master cyl vs the stock 13/16 master cyl
GET IT!!!
Doof
Quote from: fortysixandtwo on November 12, 2007, 06:09:55 PM
thanks
Quote from: LILBUDDY on November 12, 2007, 06:59:30 PM
Yes
thanks, i just got back from my dads and he gave me at least aother 100 foot of wire and other goodies...i got pics to post in a minute of it. your just gunna shake your head like so  :shake:
Quote from: Goose on November 12, 2007, 06:51:48 PM
Lookin good man.
i have them but i dont have them on yet. i cross threaded a few of them and i need to replace about 8 lugs and about the same in studs. but ill be putting them o once i get the studs and lugs
your truck is sick   :yesnod:
NorCalToy
how did you mess up your wheel spacers that bad?
:flamer: IFS
lilbuddy
Quote from: silly58willy on November 12, 2007, 07:36:38 PM
post a pic so i can  :shake:
GET IT!!!
Doof
the spacers are fine...the studs were previously   :lipsrsealed: up so when i put the wheel spacer lugs on they got all up and gone messed up so now they are useless
pics from my new haul from my dads. i got a CB antena and mount, i would guess 150 feet of wire, and a kit with wire stippers, pliers, fuses, connectors, one of those light up things that tells you weather there is current or not going to what ever your testing
NorCalToy
:flamer: IFS
KDXSR5
Doof
Quote from: KDXSR5 on November 12, 2007, 07:54:15 PM
what do you not need all that wiring for? :headscratch:
x2
i need it for CB antena, rock lights, remounting switchs, and whatever else i come across and need some extra
Quote from: LILBUDDY on November 12, 2007, 07:55:36 PM
aj...
:shake:
lol  :laugh:
NorCalToy
true taht :pokinit: is nice to have, i wasnt totally there when i posted that. my bad. wiring is nice to have, but when that :pokinit: is thrown into a box and you gott a organize all fo it (clips, connectors, etc) it blows.
:flamer: IFS
