0 Members and 10 Guests are viewing this topic.
Good crap man how about some finness!! LOL
Nah finess was me on the con trying to clearance my fenders...ask aj about that one.
using the battle ax method
oh fully. i had an ax beating the outta my fenders at the staging area, got to camp realized it wasnt enough, beat the for about 20 minutes and then it was pretty good. Actually no 2 more times i beat em up too.
what size wheel you on... 16?
i like it minus the gangsta lean from stock rear springs
Haha... I feel sorry for those guys...At my Birthday party last month, we turned my room into a dance club pretty much...Theyres some pics of me pushing guys out of the way cause they were trying to cut in and get a piece of what i was dancin with...
do you want cruise control?
so...ummmm how did you get home with no brakes?
I had that happen to me before I upgraded my brakes on my 85. I actually drove it for 2 months like that, i did have some, but very little brake pressure and like you I had to pump the pedal three times to get any pressure. So I just anticipated braking for 2 months until I swapped everything out. Im a lazy b*std . Aside from my brakes needing to be flushed and bled, some gear oil and grease had seeped from one side of my front axle and had gummed up the calipers so bad they basically didnt work worth on one side. After replacing the rotors, calipers/pads, and master cylinder, flushing and bleeding the system, they worked great. I dont think it was anything more than several large bubles of air in the system on top of the greased filled caliper though. I am nearly possitive that the master cylinder was fine but I replaced it with a V6 one anyway since I was upgrading. Try bleeding the brakes and if that doesnt work check the master cylinder and the booster. Should do the trick but if not let us know. while your at it making sure the calipers arent gunked up is worth examining too
Started by BMFN_TOY Parts For Sale
Started by J.D.Zuki Parts For Sale
Started by tonka Parts Wanted
Started by runninout General 4WD Discussion
Started by early_morning Toyota Pickup/4Runner Tech 1979-95
