Author Topic: engine mount trouble  (Read 2361 times)
Twisted_Fenders
  • Turtle Points: 2
  • Member since Mar '07
« on: Aug 12, 2007, 12:02:31 PM »
I broke my drivers motor mount and got two motor mounts from autozone and have been trying to get these things in but they sit about a 1/4 inch from where they need to be to get the bolts through the holes.  Is there some sort of trick to getting these back in?
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
Re: engine mount trouble
« Reply #1 on: Aug 12, 2007, 12:05:00 PM »
I have had to egg out the holes before to get them to work.
87 4Runner redo
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Aug 12, 2007, 12:11:58 PM »
thats the trouble with autozone parts,  best bet  is  to  bolt it to the engine  then let the engine rest on the  frame, then  drill thru the crappy made part  to make the holes right
btw  if you have dual cases  youve GOT  to chain the mounts
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #3 on: Aug 12, 2007, 01:06:31 PM »
I had this same problem with several different aftermarket mounts. The only ones that went in right were the original Toyota mounts, but they are expensive.
Twisted_Fenders [OP]
  • Turtle Points: 2
« Reply #4 on: Aug 12, 2007, 01:27:21 PM »
I have tried other aftermarket motor mounts and these are the closest to actually fitting. Do you have to go to a dealer to get the oem or someone online have them?
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #5 on: Aug 12, 2007, 01:54:02 PM »
I've never had to egg out the holes.  When you replace one side, loosen the bolts on the other side as well. use a hoist to lift the motor a bit, bolt the new mount to the motor, then run the bolts through the holes (use longer bolts to do this if you want, then replace with the right bolts later)  when all 4 bolts (both sides) are lined up in ther holes, lower the motor down.  This forces the bolts to act as a guide, and lines up the holes for you.
BTW, I have rockstomper motor mounts.  I have had very little problems getting them lined up :thumbs:
              -Ronald Reagan
12GA.YOTA
  • Male Posts: 143
  • Member since Aug '07
« Reply #6 on: Aug 12, 2007, 03:34:38 PM »
I HAD THE SAME PROBLEM IN MY 84 AUTO-ZONE, CHECKER/CRAGEN, CAR QUEST WERE ALL WRONG NAPA WAS THE ONLY PLACE THAT I FOUND MOUNTS THAT  FIT PERFECTLY. CHEAPER THAN FACTORY, HOPE THIS HELPS
84 toy 5" suspension, 2" shackle, new 35" Boggers, Detroit rear, tru-trac front, 5.29 gears, custom made bumpers f/r, custom sliders, racing seats with 4 point harness, marlin 4.70:1 t-case,stock 4 banger with sincro Webber carb
*ROKTOY*
  • Male Posts: 1,066
« Reply #7 on: Aug 12, 2007, 04:30:00 PM »
Yep, dealer
  • Turtle Points: 2
« Reply #8 on: Aug 12, 2007, 11:14:08 PM »
Well I managed to get the driver side bolts in and was then able to use a comalong to pull the drivers side down into position.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #9 on: Aug 13, 2007, 02:07:32 PM »
YES! Another NAPA user! :thumbs:
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
« Reply #10 on: Aug 15, 2007, 09:54:07 PM »
or get the solid ones from LCE.... they are badass
Last post Aug 05, 2004, 03:38:32 PM
by Mike D
Last post Feb 01, 2006, 10:23:37 PM
by yotaboy79
Last post Aug 23, 2007, 10:14:52 PM
by 91 super yoda
Last post Nov 26, 2007, 08:28:46 PM
by Gittinit
Last post Dec 10, 2009, 11:41:15 PM
by b-radhutch
