engine trouble or electrical
Started by Mike D, July 09, 2004, 08:34:14 PM
Mike D
today i was driving around and for some reason my car started acting like it does when you go through water too fast and the engine starts to lug like crazy just about ten times worse. It seemed like a few injectors stop working or the feul pump just about stoped. so that left me cruising along at avout maybe 5mph. any ideas? :headscratch: :dunno:
brainlessfool
Mike D
yotaboy79
i had the same problem but my rig is carbed and it was the carb so i dont thing my advise will help ya but yeah check the fuel filter and if that dont work replace the fuel pump if that dont work i dunno air filter? oh yeah check one more thing is there the end of a con rod sticking out of the left side of the block my friend did that lol? then ya know ya got engin trouble
Mike D
and bought a new air filter but that wouldn't cause that.
BLUCRUZ
is it still like that or did it go back to normal?
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
brainlessfool
well i think that the next thing to do is cheak the fuel press.  sould be around 37-39
Mike D
i think it was from wheeling on the weekend cause i got stuck in about 4 feet of water and about a foot of that was in my car. i don't have a fuel pressure tester i will get on though.does the fuel pump just not pump out the fuel as fast when it is going out or does it just go out.
brainlessfool
no real up or down anser on that one , if its good you'll see 37-39 lbs with the key on for awwww 10 secs.?
BLUCRUZ
You had a foot of water in your cab? if so pull your ecu and get it dried out before you put power to it again-you may have already fried it, Sorry
Mike D
i had already sealed the computer.
BLUCRUZ
still check it, that would explain your problem, See if you can get the codes from it first
BLUCRUZ
Mike D
i am still trying to get hold of a code reader. the weird thing is that the check engine light only comes on when the car hits a certian rpm then it just stays on after that still came on after i reset the computer. i drove it around today and it was fine but it only seems to happen the the engine is fully warmed up. hopefully just reseting the computer fixed it. :crossed:
BLUCRUZ
I don't know on an 87 but on my 85 if you short the t-terminal under the hood(the one you short out when you set the timing) and turn the key to "on" (don't start the engine) the check engine light flashes. Count the flashes and it tells you the code #
I have a FSM for 85 and can tell you what the codes are, I doubt they changed them from 85 to 87
Mike D
the check engine light just comes on then shuts off when i short thr t terminal and turn the key in the on position.
BLUCRUZ
ok I went and looked at my manual. Engine off, trans in neutral, all accecories off, key on, then short the t terminal. Should go out then start flasing a code, then off for 4 seconds then flashes code again, & so on & so on, Like I said my manual & rig is 85 so yours may not work that way....hope this helps :headscratch:
also if you pulled the efi fuse or disconected the batery, you cleared the codes so run it again for a while and see if the light comes back on then check the codes.
84runner
Moisture in the distributor cap or a worn out cap
Mike D
yeah i replaced the distibutor cap and the rotor and cleaned all of the connections and it runs fine know.
84runner
Mike D
yeah now it won't start all i'm getting is the open circut relay above the computer is clicking along with the starter relay. even when swaping out the computer, the open circut and the coil, the igniter the starter relay and the efi relay just does the clicking thing.
84runner
Is the starte turning over ? Or just a bunch of clicking ?
Mike D
well i bypassed my starter to see if it would engage but it just spun and that was it. so i ripped it all apart and poured all of the water out but the starter was falling appart from all of the rust in there. I just went and bought a new one. and an efi fuse cause that was bad as well. runs fine now but my front diff is leaking a quart of gear oil a day. :(
Skinny_Pedal
dam dude u are just having all sorts of problems :ack:
Im an OG
Mike D
yeah it totally sucks and my fan broke too. and my ifs rattles pings and just about any other sound you could possibly think of. :( :( :( this sucks  :moon:
Sounds like a good time for a sas to me :greengrin:
Mike D
#26
yeah I'm planning to do the sas but i have to sell my 75 super beetle first. and then i plan on the 6" orbit-eye spring front and rear with orbit eyes in the rears of all 4 springs with 1" drop hanger in front. then I'll be running 1.5" lift shackles all around. then for shock absorbers i will be getting the blistien 7100 series 14" long travel shocks. and i better out flex my friends 97 wrangler with the skyjacker 8" coil over lift.  :crossed:
        Theres 150 bucks sitting on who ramps the highest.
