Poll
What kind of locker setup would YOU run on YOUR daily driver??
Toyota Elocker F/r
10 (23.8%)
ARB Air locker F/r
14 (33.3%)
Lcokrite F/ Detroit r
8 (19%)
Spool F/r
0 (0%)
Other combos??
10 (23.8%)
Total Members Voted: 42
Voting closed: May 03, 2007, 02:51:46 PM
Author Topic: Choice of lockers......  (Read 7734 times)
rscalmo
  • Male Posts: 118
  • Member since Feb '07
Re: Choice of lockers......
« Reply #30 on: Apr 19, 2007, 11:42:50 PM »
i have a full detriot locker in the rear too! its my DD and i dont mind it at all back there, till im wheelin then i love it! ill probably do the same up front because i have manual hubs too
rebuilt 22R, downey header long tubes, 2.5" exhaust, 4 inch marlin lift with 3 inch shackles, detriot locker, 4.88's on 33's.marlin cross over steering and fror crossmember, power steering conversion, chromoly 30 spline bobby longs, 86+ wider rear axle, 12 inch 5150's all around, fully gusseted with armor...soon to be sitting on 35 bfg MT with an all pro roll cage and rock lights!
twistedtoy92 [OP]
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
« Reply #31 on: Apr 20, 2007, 09:28:09 AM »
you were happy to pay $610 for an elocker? wow, i have seen them a lot cheaper than that, you just need to know where to look
well hey man, where the hell do i look????  i at least want to put a fj80 high pinion with either 5.29 or 4.88's not sure, superlongs and chromoly hub gears up front, if i'm gonna do that i just want to put it all together the way I want it so i dont have to pull it apart all the time to swap :pokinit: out!!! the rear can stay open or go detriot i guess since everyone loves them!!! i have never used one before, i'v only got to drive spools and welded diffs!!
RAZOR
  • Male Posts: 143
  • Member since Oct '05
  • It's all about the LongFields
« Reply #32 on: Apr 20, 2007, 09:36:02 AM »
I had a lockright in rear and elocker up front. I  :love: it. I went with a selectable in front so i can negotiate tight turns and still not have a problem driving it in the snow. It might be a little  :thumbdown: driving in the snow being fully locked. And the elocker install is very easy, And cheaper then an ARB. Not to mention, with an ARB, If you ever loose air pressure or tear a line, It will come unlocked. Good Luck!  :biggthumpup:
Finally Straight Axled, e-Locker, 5.29's, Lockright Rear, 13" travel tractor spline driveshaft, CV eliminator, Fully Gusseted front axle, Marlins almighty 5" Trail Flex lift Kit, 36" TSL's
In Marlin Crawler, I trust.
If you got the Nuts, Follow my Ruts!
Lift It, Fat Chicks Can't Jump!
Motocross, Because it Requires 2!
twistedtoy92 [OP]
  • Male Posts: 3,781
  • NFM Customs
« Reply #33 on: Apr 20, 2007, 09:42:19 AM »
no doubt!!! and i like that they are FACTORY TOYOTA...... that says somethin!!  i just ordered up some more diff armor maybe i can work on my axle a little this week end, oh and go pick up my dads new 85 tonight!!! i bought him some chromo hub gears, lockrite, heavyduty seals, and a knuckle rebuild!! sounds like a fun beer drinkin tinkerin on trucks weekend!!!
RRMike
  • Turtle Points: 2
  • Member since Dec '05
« Reply #34 on: Apr 20, 2007, 05:29:16 PM »
I was concerned about the same thing but it goes great in the snow.  Not difficult to turn and doesn't understeer noticeably.  On Ice it might suck but I've never noticed a single bad habit in the snow.  It just won't stop :D
RynothealbinO
  • Turtle Points: -15
  • Male Posts: 141
  • Member since Aug '06
  • 36's on no lift!
« Reply #35 on: Apr 22, 2007, 04:46:39 PM »
I would weld/spool the rear end and put some type of selectible locker in the front end.  My rear is welded and I drive 35 miles everyday, and I love it.  I had a automatic locker in the rear and I hated it because it locked and unlocked constantly jerking the truck side to side, plus it only worked right for about 15 miles.  But if you have the money put a selectable locker in the rear.
Trust in the LORD with all your heart and lean not on your own understanding, in all your ways acknowledge him and he will make your paths straight.  Proverbs 3:5-6  Don't let anyone look down on you because you are young, but set an example for the believers in speech, in life, in love and in purity.  1 Timothy 4:12
twistedtoy92 [OP]
  • Male Posts: 3,781
  • NFM Customs
« Reply #36 on: Apr 22, 2007, 10:39:56 PM »
yeah i have a spool in the 85 but i drive my 92 in town ALOT!!! and i dont like the jerky chirp chirpin of the welded and spool on the pavment!!! i just hate that selectables are so expensive!!
Knucklehead
  • Turtle Points: -23
  • Male Posts: 56
  • Member since Sep '04
    • Right Coast 4x4
« Reply #37 on: Apr 23, 2007, 12:10:54 PM »
If I had the money, ARB Air front and rear.
Being me, Aussie front and rear. :thumbs:
X2
I currently run a spool in the rear with nothing in the front.  I find myself DDing my junk less and less these days.
'85 Toyota P/U
5.29s w/ Rear Spool
Dual Cases w/ MC07
4" Marlin Lift
35" BFG MTs
Thor84
  • Male Posts: 42
  • Member since Mar '07
« Reply #38 on: Apr 25, 2007, 10:22:21 PM »
i have a friend who just put in a lockright in the front and an aussie in rear
he was going to put both lockright in front and rear but heard that the aussies dont make as much noise in the rear
but thats just what i hear
i guess money is a real big factor on what locker you can buy
when i get a little more money saved im probaly going to put a aussie in the rear
but im sure what ever you decide it will be better than not having a locker
How can i have another Nutter Butter Peanut Butter Cookie Dookie Sandwhich, if i have not had my first Nutter Butter Peanut Butter Cookie Dookie Sandwhich?
TexJeff87
  • Turtle Points: 4
  • Male Posts: 51
  • I wheel in my yard...
« Reply #39 on: Apr 26, 2007, 06:17:53 AM »
X2   :thumbs: :thumbs: :thumbs:
grease under 'ma nails....
formerly a cherry sas'd 87 runner, now an assortment of dents
35's, lockers, and a canback
twistedtoy92 [OP]
  • Male Posts: 3,781
  • NFM Customs
« Reply #40 on: Apr 26, 2007, 10:25:21 AM »
alright, fj80 high pinion elocker with 4.88's front and V6 rear 4.88's and a detriot!! that sounds like a nice setup for optimum trail/DD/rockcrawler!!
RAZOR
  • Male Posts: 143
« Reply #41 on: Apr 26, 2007, 10:29:04 AM »
 :rockingout:  :thumbs:
twistedtoy92 [OP]
  • Male Posts: 3,781
  • NFM Customs
« Reply #42 on: Apr 26, 2007, 10:35:58 AM »
how you like your lockrite Redneck??? i'm getting ready to drop one in the front of my dads 85.....
Redeyejedi
  • Male Posts: 115
  • Member since Jan '07
« Reply #43 on: Apr 26, 2007, 04:13:22 PM »
isn't it harder to drift in the dirt while the rear is locked? the detroit engages when a wheel begins to spin faster than the other side right?  :headscratch:
alcohol.....the cause of, and solution to, all life's problems
http://www.flickr.com/photos/78234902@N06/
RAZOR
  • Male Posts: 143
« Reply #44 on: Apr 26, 2007, 08:33:57 PM »
Negative. I know my lockright engages under any cituation as soon as you put power to it. I think the detroits do as well. Some people claim that the detroit is smoother around corners.  :dunno: My friend has one in his V6 daily driver (don't know why he got it) But i rode with him a couple times and didn't notice much, at least an extra $200 worth. People claim that they can hear the lockright lock and unlock, but i still haven't herd a thing.   :biggthumpup: :twocents:
Last post Oct 03, 2010, 12:24:52 PM
by Travis H
Last post Oct 17, 2010, 11:22:02 AM
by 12GA.YOTA
Last post Mar 26, 2012, 10:04:51 PM
by David
Last post Jun 27, 2013, 07:34:33 AM
by Jr0mer0
Last post Nov 26, 2020, 07:04:35 AM
by trigrate
