stock configuration on the 2wd is mounted to the u bolt plate..... several people run them on the axles....i think either is fine
jimbo, gittinit...Come awn guys. Now ya'll ain't making it easy for me to get started here.I'm like a kid in a candy store - ya gotta give me a reason to go one way or another.I guess, by default - I'll side with the high-paid engineers that work for Toyota, and do it the way it was done. No need to re-invent unless you got some science for a cause to do so.Thanks.
If ya want to talk angles / \ vs. vertical then I would say verticle is better even though I have mine mounted like / \ this.
the shock will be most effective at vertical. the main reason people mount them like /\ is for space reasons. this is correct, right? if u can cut thru the bed, more vertical is better right?
more vertical will dampen better however... it will also limit articulation.... when the vehicle leans, the aqxle wnats to move away from its relative position to the frame, the more verticle the shock, the less the axle can deflet
One advantage to going onto the axle would be a longer shaft and stroke. .
Started by blackdiamond Parts For Sale
Started by Lonestar Honcho Parts Wanted
Started by RN37DD « 1 2 » Engine
Started by Skim Parts For Sale
Started by lone walker Parts For Sale
