4x innovations makes a kit but i don't know how much it runs edit: http://4xinnovations.com/pages/guarding/hingekit.htm
supposedly, if you drill and bolt, they get sloppy. slotting the cab side of the hinge like a U Cis supposed to be the way to go. Yet I have not done either.
i did it to mine, works like a charm. Takes about...5 minutes to get them off, a little longer to get them back on if you're doing it alone, the hinges can get turned while you're trying to set them back on, but its def possible. Works great, glad I did it.
I did mine over a year ago and it worked out great. The top hinge on the truck.. I cut the top off and weld it to the bottom half to beef up the hinge.The pin it self is a little shorter.bottom hinge. the pin is a little longer.door side of the hinge.top hinge as one unit.bottom hinge as one unit.the concept behind my way is that you don't need to add or remove any pin....although, I do use the center pin between the two hinges to keep my full size door from swing out if the wind blows hard while the door is open. You do have to find a happy medium between the two sets of doors. and the brass bushings do have to be cared for and not loose them. I change a door out in under a minute....shut both doors for that matter.MikeThe bottom hinge needs to be set in place with been before positioning the top hinge/pin. and same in reverse. Lift up door and pull out on top then remove bottom.One last note and this may be the deal breaker. You do have the modify your front fenders some. I just remembered. let me see if I can find a pic.at the bottom of the A pillar the fender needs to be trimmed some about 1/4" right at the corner. doing so lets the door pull up. I would thing if you had the bottom pin the same size as the top maybe you would be able to get away with it. I left the bottom pin longer and use it as a guide to set my doors in place. First bottom and the top....to remove first top then bottom. My hands are short and stubby so I know what you mean.
Wouldn't this be a whole hell of a lot stronger? and extremely cheap:
and extremely cheap
It comes up ok for me, let me attach it.I'm linking it from Pirates, so that's the problem.Well I don't know about this, I mean you need to buy a bolt!
I use a 10 mm socket.
Started by HFCRAOffroading General 4WD Discussion
Started by norcalyoter Project Research and Build-Ups
Started by YotaDave General 4WD Discussion
Started by CrankyCrawler Toyota Pickup/4Runner Tech 1979-95
Started by dixiepc Parts Wanted
