found!!!!!!!!!!!!!!!!!again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Started by 79toy20r, February 12, 2007, 12:23:16 AM
79toy20r
A few pictures for you guys...
This last summer before the timing chain tensioner went out on me. It is a 79 20r. In this picture I have 2wd f150 leaves in the rear minus 1 leaf with stock shocks that are fully extended in the picture with more room to go down with the front hanger moved forward about 3inches. A 2inch front drop hanger with stock springs.
Once I finally got it in the garage
The rebuilt head with lcengineering 44mm stainless steel intake valves and 36mm exhaust valves, hd valve springs, .440 lift cam
New timing chain set from lc engineering
Starting to put it back together. I need to clean up the engine bay a little. Hopefully the cam and valves will help the little 20R with the 38 weber that I need to get rid of
Now I just need to finish putting my leaf packs together, move the rears up front and  put the f150's in the rear. Install my IFS box and marlin highsteer. And then save up for some gears and lockers....
yotaweelr
looks like my truck about 8 years ago, but mine was yellow.
yea  a 38 weber  is  too big  for a 20R,  but  if  that guy in georgia  doesnt swap  me  i'll swap  my 32/36  that was originally jetted  for a  hopped up 20R,  for your 38,  cause  my  3236  is  too small  for my  motor,  :down:  i need a 38  BAD
YODAWILL
79toy20r
Thanks for the comments. I will post up some pictures when it's done. I hope do get it painted here pretty soon so I can get rid of the primer and surface rust.
79toy20r
Ok so I mocked up my long tube header and I am a little worried. It drops below the frame about an inch. Is anyone else running a long tube header? Have you had any problems snagging it on rocks or anything?
And here it sits below the frame....Should I run it or stick with my shorty header??
rednk1980
I'd stick with a shorty just because thats what i run in all my rigs I don't think you'd catch it on anything but the shorty tucks it up alot nicer.  :twocents:
79toy20r
Pulled the rest of my parts out of storage tonight. Marlin highsteer, IFS steering box, Tall shock hoops from marlin, 5100 14" bilstiens,1" master cylinder. Started putting my spring pack together for the front
79toy20r
4inchToyotas
excellent..another blue 1st gen!
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
79toy20r
Yea hopefully after the suspension is done it will get a nice new coat of blue too...
4inchToyotas
mine gets some new rustoleum safety blue any time it visits with the trees
brainlessfool
I've never had any trouble hitting my long tube header, butt I don't do any real "hard core" rock crawling. just wheel to get where I want to go.
and get rid of that fram O/F now!
79toy20r
Yea I'm just using the fram for the first 500 miles for the break in of the new head and then I will change it out....I don't plan to do a lot of hard core rock crawling, but where we go there are a lot of "kelly humps" I was worried about catching it on them. So I just stuck with the shorty.
boggerunner
nice truck, and what is wrong with fram oil filters?
79toy20r
Axle truss welded on and painted
79toy20r
Finally got some time to get the front suspension sorted. Got the axle underneath it and the fj rotors with IFS calipers. Now I just have to get my steering box put on and weld on the shock hoops.
Tallchevy
Looking good. Looks like you have to paint the body now that the under side is clean
87 4Runner redo
79toy20r
Quote from: Tallchevy350 on July 22, 2007, 10:24:01 AM
Yea I wanted to finish up the drivetrain and then the body will get its share of love along with the interior.
Thanks for the comments guys
gtoyonrocks
I say don't worry about the body, maybe some primer. I took all of the interior out of my truck, it's a rock truck, and it looks like it. I guess differant strokes for differant folks
79toy20r
What do you want your front pinion angle to be? I need to order some shims for the front axle. Thanks for any help
yotameister
Nice Blue first gen, lots of em out there but they look great when done
:driving:DRIVE ON:driving:
Yoat Goat
Nice truck man! Looks great!
T urning
O ver after
Y ears
O f
T rail
A buse
rednk1980
its funny my truck looked exactly like yours when i started and the i got ahold of it and two years later i've got what i got. Keep it up looking good.
Gewehr43
Nice Progress!! The the 1st Gens!
AaronB
DanS
Very clean work  :yesnod: nice first generation
DanS
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
79toy20r
#29
Hey guys my rig was stolen yesterday in spokane, washington. So anyone in the PNW please keep your eyes out.
