Rigs with 40s+ Gallery
Started by alwayzbroken, February 11, 2007, 08:29:48 PM
alwayzbroken
There a ton of people running big meats around here. Post pictures of your rigs and specs on what you have done to make it survive (i.e. cryoed diffs, 23 spliners, hub upgrades etc.). I would like to see if we can establish a baseline of what is necessary to run very large tires (40+)and what most frequently breaks.  :beerchug:
Rockcrawlintoy
1991 Toyota ex cab 22re dual cases and locked front and rear.
The front end is stock other then the gears and locker. i just keep the arb off most of the time and if i am in a situation when i think i might break ill turn it off. I have only wheeled the 40s once so i still have a long time to break them. I am saving for a new rear end and alloy axles and long field joints with deadenbear knuckles for good measure
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
iNfErNaL
Running 42s with 1 Ton axles.Axles are stock other than 5:13s and lockers,would like to get Deadenbears and chromos....Oh yeah,and the POS breaks all the time  :gap:
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
Gittinit
I would like to see more toyotas running stock axles(upgraded of course) here. You guys give us something to aspire to.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
JZ
Heres mind yota running birfield elim.
Austin W
pic of mine, have hydro assist in front to help turn them and a dana 44 with crm shafts and oxes to support them, oh and stock toyota v6 8" rear...
rude86
nice lookin rigs i dont have any pics of mine yet. im runnin 60 front 14 bolt rear. 44"s and 35 splin cromo fronts.  in the middle of the build up on it.
member of team marlin crawler
yota_krawler
My buddies truck on 39.5s now it has 42 inch irocks pic later. It has 5:71's, dual case, 88 straight axle swap, efi ifs hubs, rotors, and spacer's ifs rear end. SR5
Shamb
1-ton axles w/ 35 spline outers on the front. Currently running 42" iroks.. i'm content w/ staying at a 42" tire... nothing bigger.
iNfErNaL
Quote from: Yota_Krawler on February 18, 2007, 03:34:57 PM
Nice truck,how long has he been running the 5:71s?.I have a buddy the broke 2 sets on the street and then went back to 5:29s.
alwayzbroken
Do have pictures with the 42s?
yota_krawler
No not yet, he rolled it with the 39's and just now got it out of the shop with a new cab, He hasn't broken a gear they are US gears and seem to be doing good. He has had to put new seals in the rear with new wheel berrings, when the berrings broke he did chip his ring in the rear but it is not bad at all he had it re ground.
yota_krawler
is that all the people who run 40+? huh would of guessed a lot more the 39.5 seems to be a popular tire. Where's the 44's 49's 54's? any one seen the new bogger on anything it looks huge!
yotaboy79
heres my junk 79toy 39.5 iroks in the front its got yukon 5.29s, welded, 30splines longs, arp hub studs soon to have drive flanges/hydro assist and home made 5th stud settup for the knuckles, the front housing is also shaved,gusseted top and bottom with ball guessets the rear has yukon 5.29s welded with a shaved housing
so far the only thing ive broke with the 40's was the stock hub studs and both dowel pins on the pass. side
KYOTA
hey bizatch when was that crushers trip and why dint you call me  :slap:
oh, cool vid BTW  :greengrin:
yotaboy79
a couple weeks ago and i didnt call cus i dont have your number btw i did upper and lower in 3wheel drive with out any problems but it was a little interesting comming back up from the lower crushers pm me your number and ill give you a call next time we go out where normaly up in trask every sunday or every other sunday and browns camp once a month or every other month
Tice
Here's mine on 39.5 IROK's. 5.29's and 30 spline hydro assist front and 5.29's stock rear. Both with spools. Yet to break anything. :shhh:  Notice the broke yellow heep? :gap:  The last pic was just a cool pic.
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
KYOTA
Quote from: yotaboy79 on March 11, 2007, 02:53:32 PM
I still want to find the Prineville mecca too
Lizard_lips
#19
here's my truck with my old 39's on it
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
Lizard_lips
oh yeah the specs are350-350-205 14 bolt D44. going with CTM and Chromos.
yota_krawler
This is the same maroon truck with 39.5's. He did a cab swap and now is on 42's
alwayzbroken
Quote from: Yota_Krawler on March 13, 2007, 10:22:27 PM
Sweet truck! That thing is huge with those 42s. Do have any more pictures from the front or rear so we can see how much air is under the diffs?
Shamb
I think people are forgetting the purpose of this thread, its great to see your rig and all... but we need specifics on what axle's you are running and what modifications have been to keep those wheels turning.
:thumbs:
alwayzbroken
Quote from: Shamb on April 09, 2007, 07:16:29 PM
:thumbs:
Yep, thanks Shamb.
6.72:1
Let me get some photographs....
Peter
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
yota_krawler
Quote from: alwayzbroken on April 09, 2007, 03:39:57 PM
He just rolled it on the 7th 9 times. So I will put up more pics.
alwayzbroken
Quote from: Yota_Krawler on April 10, 2007, 12:41:30 AM
Would the height of the truck have anything to do with that? Nah....... I doubt it.
gotrocks
Quote from: alwayzbroken on April 10, 2007, 10:28:31 AM
:laugh: :rofl2:
gotrocks
here's my buddies FJ on 42's
Ford HP60 wtih tubes swapped up front with cromo 35 spline outers and old school 60 rear 4.56 f/r
sbc350/TH350/atlas
so far nothing has broken yet on him with this setup.  We have run the crusher trails and done nearly everthing at browns camp.
