ok, i think i figured it out. 2.4L(2RZFE) came in 2wd and (3RZFE) 2.7L's came in 4wd, right? i think the seller got confused and messed me up. thanks.
The 2.7 is in all 4x4's with manual trans. If it has an auto trans it is def a 2.4 I've run into this at work on several occasions.JFYI You can use a 2.7 3rz head on the 2.4 2rz block.
if it is a 2.4L, will a 2.7L bolt right in?
i'm looking at a 2000 tacoma 4x4.
In general, I would recommend to try to get an engine that is as close to 1995 (if 4cyl) or 1996 (if V6) as possible, since this is the first year for OBD-II and will have the least amount of emissions related equipment (if applicable).
Wait............Are you serious? It is a 2000 4WD And it has a 2.4L I don't know why I didn't catch that when I replied last.This is impossible. FWIK There is no such thing as a 4WD 2.4l Tacoma.Got any pics
Started by christyle Toyota Pickup/4Runner Tech 1979-95
Started by GM Man General 4WD Discussion
Started by 4Wheelin General 4WD Discussion
Started by 12 valve Engine
Started by tom85 Toyota Pickup/4Runner Tech 1979-95
