Author Topic: SAS frame question  (Read 2609 times)
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
SAS frame question
« on: Dec 25, 2006, 09:47:14 AM »
I'm doing a sas on my 87 4Runner. When I cut the holes for the front shackle pins, I found that the metal is very thin between a retangle factory hole in the frame & where I cut. Is this a problem? Should I make a plate to reinforce that area or is it ok the way it is?
87 4Runner redo
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: SAS frame question
« Reply #1 on: Dec 25, 2006, 09:49:33 AM »
you should have cut lower,  but  do the other side the same,  and YES  reinforce the entire area with some 1/8  or 3/16  plate
Tallchevy [OP]
  • Male Posts: 3,562
« Reply #2 on: Dec 25, 2006, 10:04:15 AM »
OK, thanks. I used the template that came with the kit but the kit didn't come with instructions.
87 4Runner redo
_HOIST_
  • Turtle Points: 300
  • Member since Jan '06
  • Slow is smooth, smooth is fast
« Reply #3 on: Dec 26, 2006, 07:14:24 PM »
Damn I would plate it all and recut the holes man. Itd be a pain to plate only the top and those holes being so close is scary as hell
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #4 on: Dec 26, 2006, 07:21:45 PM »
x2, not something to be taken lightly
Quote
Tallchevy [OP]
  • Male Posts: 3,562
« Reply #5 on: Dec 26, 2006, 07:32:55 PM »
What I'm going to do is make a plate that comes 2" above the hole that way I can still get the welding tip up on top & make a "C" notch that will go part way around the shackle tube & weld it all togther. I'm using 1/8" plate which will be thick enough I think.
87 4Runner redo
_HOIST_
« Reply #6 on: Dec 26, 2006, 07:35:09 PM »
Just imagine cruisin down the road or wheelin and ur frame takin a complete dump! Not cool at all.
_HOIST_
« Reply #7 on: Dec 26, 2006, 07:36:55 PM »
Sounds good. 1/8 inch should be all you need.
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #8 on: Dec 26, 2006, 07:42:01 PM »
notching out the top plate for the sleeve would be about the best you could do.  it would probably be stronger than stock if you did that.
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #9 on: Dec 26, 2006, 07:48:51 PM »
what do u mean exactly? wouldnt it be better to just plate the whole thing and start over drilling a new hole?
Quote
Ramrod
  • smelling like vag and loving it
  • Turtle Points: -59
  • Male Posts: 3,600
  • Member since Jan '05
  • fully bodied & Fully getting it
« Reply #10 on: Dec 26, 2006, 07:51:18 PM »
just weld it in like that, flop It!!! :flamer:
wheres it gonna go?
_HOIST_
« Reply #11 on: Dec 26, 2006, 08:02:36 PM »
All I'm sayin is that I'd rather be safe than sorry. Itd suck to have a dicked up frame. I would weld 1/8 over the whole thing and redrill for sure.
_HOIST_
« Reply #12 on: Dec 26, 2006, 08:03:31 PM »
Oops those pict weren't supposed to be in there. . .
Tallchevy [OP]
  • Male Posts: 3,562
« Reply #13 on: Jan 01, 2007, 01:18:31 PM »
This what I did. I used 1/8" plate x 5" long. I marked the plate in the center [2.5"] & used a hole 1 1/2" hole saw & drilled. The I cut the plate in half at the hole then made 2 plate. Fitted them above & welded.
87 4Runner redo
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
« Reply #14 on: Jan 01, 2007, 04:26:22 PM »
looks perfectly fine.
  • I'm Legit!!!
  • Male Posts: 6,715
  • AKA Baja Brad
« Reply #15 on: Jan 02, 2007, 05:41:19 PM »
that's what i ment.  it should be as strong if not stronger then stock.
Tallchevy [OP]
  • Male Posts: 3,562
« Reply #16 on: Jan 02, 2007, 08:36:50 PM »
Thanks for the help.
87 4Runner redo
Last post Apr 27, 2004, 12:11:58 PM
by motorfreak21
Last post Sep 05, 2003, 10:01:23 PM
by grease_monkey
Last post Jan 24, 2006, 01:53:06 AM
by 86 4runner
Last post Apr 10, 2006, 11:35:59 PM
by robrub00
Last post Aug 10, 2006, 07:20:00 PM
by 79coyotefrg
