Author Topic: Colorado  (Read 161579 times)
jarboarder1
  • Male Posts: 212
  • Member since Oct '07
  • Rocky Mountains
Re: Colorado
« Reply #600 on: Jun 28, 2010, 04:24:47 PM »
Does anyone have left over parts from making dual cases??
I cracked the aluminum on the back part. this is just a leftover piece if you did duals.
Also if anyone has a pillow bearing from a two piece drive shaft Im looking for one of those also.
Thanks
uglyota
  • Male Posts: 45
  • Member since Nov '05
Re: Colorado
« Reply #601 on: Jun 29, 2010, 04:48:47 PM »
I got your transfer case pieces.  Where are you located?
jarboarder1
  • Male Posts: 212
  • Rocky Mountains
Re: Colorado
« Reply #602 on: Jun 29, 2010, 10:53:12 PM »
Great. Im either in Greeley or Golden depending on the day. where are you?
uglyota
  • Male Posts: 45
Re: Colorado
« Reply #603 on: Jun 30, 2010, 07:10:56 AM »
Denver...sending PM
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Colorado Rocks!
    • http://www.rockfrogs.org
Re: Colorado
« Reply #604 on: Jun 30, 2010, 07:44:10 AM »
I also have the t-case parts but I'd have to ship them from Pueblo.  Let me know if you need them.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
jarboarder1
  • Male Posts: 212
  • Rocky Mountains
Re: Colorado
« Reply #605 on: Jun 30, 2010, 05:16:23 PM »
Thanks for the help guys, but a guy down the road from me has what I need so Im just going to grab it from him.
I appreciate it though :beer:
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #606 on: Jul 07, 2010, 08:33:48 AM »
Denver...sending PM
You coming to the Colorado 4Runner Jamboree in 3 weeks??  Most of the people that are posting in the CO are going.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
uglyota
  • Male Posts: 45
Re: Colorado
« Reply #607 on: Jul 07, 2010, 11:12:56 AM »
Will be out of the country, unfortunately.  Was out of town for last year's too :(
Will catch up with you guys one of these days
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #608 on: Jul 07, 2010, 11:42:04 AM »
No worries, just wanted to make sure you knew you were invited!  I still think we need to have more than 1 Toyota-based event throughout the year.  The CO4RJ is a blast.  I look forward to it every year.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #609 on: Jul 07, 2010, 10:22:31 PM »
Finally got some work done on the 4Runner.
If you remember, this is what my driver's side quarterpanel looked like with the 4Runner tailgate.
And what it looked like after converting to a truck tailgate
After quite a bit of welding, grinding, and laying my first body filler - here's what it looks like now
It still needs more sanding and some primer but it felt good to make it look somewhat better than it did before.
Also worked on the front bumper.  After adding a winch, the front receiver hitch is blocked by the roller fairlead.  I cut the Trail Gear winch mount reciever out and added a new piece of 2.5" x 2.5" under it.  I now can use both the roller fairlead & front reciever hitch at the same time!
With the winch installed
Installed the winch Monday night and realized that warn doesn't supply the M8000 with a solenoid bracket to mount the solenoid control box to the winch  :shake:
I had to cut off the forward facing light tabs to install the winch.  I also had to cut down and pound out one of my front rock light tabs.
Here's the Warn bracket for $12
Here's mine for free (minus about half an hour of labor)
What it will look like installed.  Still needs painted.
Also worked on the rear bumper on Monday.  I decided to cut out the rear crossmember that I had tacked into place 4 years ago.  I didn't feel it was beefy enough to mount a rear bumper to since it was only 1/8" thick 2" x 3" tubing.  The rear tailgate support is now welded to that crossmember.
Tailgate supports welded back onto the 1/4" thick 2" x 3" rear crossmember.  I used some 1/4" plate as spacers after having to cut & grind them off of the old crossmember.
Ready for a rear bumper
Rear crossmember isn't coming out any time soon  :D
Adding some 2" x 2" .120 wall supports towards the middle of the crossmember to an existing crossmember.  Should help with the heavy pulls from the planned middle reciever hitch in the rear bumper
Adding some corner gussets as well to help with those heavy tugs
Starting the tube work for the rear tube bumper.  Took my dad & I quite awhile to figure out the bender to get these 2 pieces bent.  Hopefully the rest will go faster.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
coloradocrawler
  • Male Posts: 99
  • Member since Jun '09
  • function WAAYYYYYY before from
Re: Colorado
« Reply #610 on: Jul 08, 2010, 12:26:31 PM »
looks good volcom. im heading the same-ish direction for my rear bumper too, round tube that is. are you gonna incoporate a reciever in it? did you ever so something about the tailgate being bolted to the mount without a rubber spacer? i read on rockfrogs (i think) about someone mentioning it, that the tailgate would bind during flex?
11C's. We are snipers too, just with bigger bullets.
87 4runner- 3.4L, ARB f&r, 5.29, longs, 39.5in IROKS, duals with a 4.7, body and topper bob'd 11in, way too much lift, and an extremely high credit card parts bill!
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #611 on: Jul 08, 2010, 02:00:05 PM »
Yeah, the rear will be based off of a receiver.  It will be directly welded to the rear crossmember.  Same with the other bumper supports (they will be .120 1.75" tubing though).  The rear bumper will also get a swing-down tire carrier (not before the Jambo though).
I honestly forgot about the tailgate talk about possible binding while being flexed out.  I guess I'll find out :D
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
wakkjobb
  • Turtle Points: -18
  • Male Posts: 1,590
  • Member since Dec '08
  • Back at it after 5 years!
Re: Colorado
« Reply #612 on: Jul 08, 2010, 02:49:45 PM »
What about a bob in the future??  :eyebrow:
Looks great; are you pushing to have it painted before the Jambo or just concentrating on getting it trail-ready?
>>Dan
IronClad: If I wanted to hold hands and be nice I'd become a hippie.
coloradocrawler
  • Male Posts: 99
Re: Colorado
« Reply #613 on: Jul 08, 2010, 04:02:47 PM »
>>Dan
i second that question
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #614 on: Jul 08, 2010, 07:49:23 PM »
No bob planned yet.  I like having it full body.  So far, the full body hasn't stopped me on the trail :D
Might be a suprise.  It will be trail ready but maybe more.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
wakkjobb
  • Male Posts: 1,590
Re: Colorado
« Reply #615 on: Jul 08, 2010, 08:05:40 PM »
...I see housepaint applied with rollers in your future...
 :gap:
That's what my pile has; lumpy-bumpy paint.  :shake:
>>Dan
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #616 on: Jul 09, 2010, 06:50:41 AM »
I've already bought the paint.  It's alittle better than house paint but not by much :D
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
uglyota
  • Male Posts: 45
Re: Colorado
« Reply #617 on: Jul 09, 2010, 10:07:30 AM »
solid work.  I like the taillight replacements.  Did you bend/roll those corners yourself or does someone offer them?
coloradocrawler
  • Male Posts: 99
Re: Colorado
« Reply #618 on: Jul 09, 2010, 10:40:00 AM »
just finished the bob on my runner. i decided to repaint the whole truck and get rid of the chipping paint- i went with white primer in a rattle can   :yikes: :shake: :puke:. i wanted an easily touch-up able paint scheme. oh well, function before form.
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #619 on: Jul 09, 2010, 11:54:05 AM »
A friend of mine & I rolled them at his dad's sheetmetal shop.  I've gotten so many requests to make more & sell them.  Just trying to figure out a way to make them faster.  These took us 30 minutes to do (granted they were our first set).  I was tired of breaking stock taillights and at $30 a lens a piece, it was getting expensive.  These lights are $12 if I break them.
I've been rocking "function before form" for years now, hence the 5 different colors on my rig :D.  White primer paint job sounds like a perfect solution for a crawler paint job!
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
coloradocrawler
  • Male Posts: 99
Re: Colorado
« Reply #620 on: Jul 09, 2010, 03:50:26 PM »
you know it doesnt look too bad. but you cant put dirty hands on it cause the dirt transfers. i left the rhinolining on the bottom of the truck and painted everything above it. i didnt do that great of a job trying to protect the lining. so its kinda ghostly looking. i have plans on removing the lining and painting there later. when i lived/worked in madison WI one of my workshirts was a barney shade of purple with a light yellow company name embrodoidery-- i lived with that so im sure i can live with an ugly looking paint job for a while. :rofl2: :hammer:
i just took a better look- you used the same lights i did- both brake lights and trun signal lights :biggthumpup: :beer:
« Last Edit: Jul 09, 2010, 04:03:26 PM by coloradocrawler »
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: Colorado
« Reply #621 on: Jul 09, 2010, 09:36:26 PM »
lookin good volcom, i prolly wont make it to the jambo this yr, im spotting for my buddys f-toy in we rock at salt lake that weekend.
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #622 on: Jul 09, 2010, 10:24:45 PM »
Russell said in another Jambo thread that you wouldn't be there, sorry to hear that!  But you've got a good excuse, good luck at the comp!!  Any pics of your buddies F-toy??  I've been interested in going that direction one of these days.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
Re: Colorado
« Reply #623 on: Jul 10, 2010, 09:11:56 AM »
heres a few from az
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #624 on: Jul 11, 2010, 08:07:47 AM »
Got some more work done on the rear bumper yesterday
Trying to get it sitting where we wanted it.
Reciever hitch for a rear tow point
Sometimes you just have to find the "right" combo of stuff to help hold your stuff level  :greengrin:
Right side tacked, left side getting ready to be tacked
All tacked on
Trimmed the tube in the front to match the rear of the wheelwell.
Here's what the sides will look like.
Here's the rest of the bumper.  I'll need to notch and cut them and they'll be ready to weld in.
Another rear bumper pic
Frame tie-in for the front part of the bumper
Used a 1/4" scab plate on the frame.
The hitch pin hole is close to the rear tube but should work
Bumper support tube to rear crossmember.  No scab plate needed since the crossmember is 1/4" thick.
Rear reciever hitch tubing welded to crossmember.  I'll add a gusset to the bottom.
Side profile of the bumper.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #625 on: Jul 11, 2010, 08:08:57 AM »
heres a few from az
Sick pictures!  Who's buggy?  Clint's?
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
Re: Colorado
« Reply #626 on: Jul 11, 2010, 09:04:01 AM »
nope, dunkins buggy, clint has an bronco
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #627 on: Jul 11, 2010, 11:04:36 AM »
I knew he had a Bronco but I saw the Battlement sticker on the side I thought maybe he also built an F-Toy.  Sick rig Dunkins has built.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
coloradocrawler
  • Male Posts: 99
Re: Colorado
« Reply #628 on: Jul 12, 2010, 10:53:41 AM »
it looks like my idea is the almost the same as yours for the rear bumper. the only thing i had different was that i am gonna try to bend the bumper twice so the bumper is also the bumper mount on the outside frame. but everything else is the same.. tell me how it works- then i can change my design to make it better :thumbs:
i see your side hoop is close to covering up turn signal- are you going to leave the hoop at that height and worry about the turn signal, i feel that those lights do not produce alot of light and even without a hoop there it might still not be seen. ( i know, i know- its a rockcrawler thomas= who cares.) just wondering?
 :beer:
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Colorado
« Reply #629 on: Jul 19, 2010, 12:14:33 PM »
I was originally going to build mine that way.  I'm still learning to bend tube so I tried to minimize the amount of bends that I could screw up :D
The turn signals are going away.  I kinda put them on as a temp fix until I could wire in a trailer taillight converter that I bought last year (to make the red LED's blink as a tailight).  Those yellow LED's are leak.  They can only be seen at night.  I'll just weld up the holes I drilled in the sheetmetal tailight holders.  The bottom inch or 2 of the red LED's might be covered but there's 4 inches of light above so that should work out OK.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Last post Sep 16, 2008, 01:25:19 PM
by OldSkool
Last post Sep 15, 2008, 07:30:06 AM
by Volcom
Last post Sep 15, 2008, 07:40:31 AM
by Volcom
Last post Nov 27, 2008, 08:37:36 PM
by *** YELLER ***
Last post Nov 25, 2009, 06:04:28 PM
by bcjoseph23
