Yup...you might want to open each rear valve and just push fluid right through it...your problem is that you have to get the lines plus the cylinders filled with fluid...thats quite a bit of air.Another solution is a pressure bleeder which will go much more quicker...
I've been using the buddy system. The wife was sitting in the truck for like 2 hours on a couple of different days. Pumping and holding but still air in the system.I just thought of another strange thing. If she would pump the pedal like 5 times and hold it down, and I open the front brakes or the proportioning valve at the rear, the pedal goes down to the floor. If she pumps and holds and I open either of the rear brakes, the pedal does not go down.what should I check next? Do I need to take the wheels off now and check to see if the wheel cylinders are leaking in air somehow? Or just keep pumping and holding with my little glass jar and rubber hose?Does that help any more?Greg
Can you buy a power bleeder for a reasonable amount? If one is not too much money, I might just try that. What does one cost?
The LVSP arm the that weird arm that goes from the proportioning valve and bolts with 2 bolts to the left side of the rear axle, right? I never did understand what that thing did. So I should tie it all the way up and then try bleeding again?I'll try that and let you know.thanksGreg
Started by SWAMPER General 4WD Discussion
Started by Makohon Toyota Pickup/4Runner Tech 1979-95
Started by Yota Up Toyota Pickup/4Runner Tech 1979-95
Started by *** YELLER *** General 4WD Discussion
Started by Jakesteads Engine
