Author Topic: Simple questions about bleeding brakes.  (Read 1457 times)
Yota Up
  • Turtle Points: -4
  • Member since Feb '06
« on: Sep 19, 2008, 01:01:38 PM »
1985 Toyota.
1) What is the difference of having the truck running while you bleed them vs. having it turned off? Under what circumstances would you want it running instead of off, why?
2) What's the difference of having someone push and hold before you open the valve vs. opening the valve and then having them push and hold? Why would do one instead of the other?
3) How many squirts should be done on each valve before moving onto the next one? (Assume there's no air bubbles or dirty fluid coming out the entire time.) 5 times each?
I'm bleeding it over and over(including the LSPV). Wife tries to help but baby cries and the operation stops.
I'm gonna be selling this truck but can't let someone drive it away when the pedal goes to the floor and you have to pump the brake once or twice before you get real brakes. If I'm going to require someone to bring a trailer to get it and let them deal with the brakes - should knock off a few hundred bucks?
Great rig other than this brake issue I got. I've put 3 small containers of brake fluid through it and while I did see a little air here and there - is it possible for more air to still be trapped along the lines?
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
Re: Simple questions about bleeding brakes.
« Reply #2 on: Sep 19, 2008, 01:53:52 PM »
try to gravity bleed them if your are doing it by your self....
the truck does not have to be running to bleed the brakes :twocents:
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #3 on: Sep 19, 2008, 01:58:49 PM »
Don't forget the bleeder in the rear on the load sensing valve..........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Yota Up [OP]
  • Turtle Points: -4
« Reply #4 on: Sep 19, 2008, 03:56:47 PM »
Didn't forget about the LSVP.
Although now that I think about it, I never bench bled the master.  Could that tiny amount of air in the master be responsible for this?
Guess I'll jack up the rear tires and do the master.  Do I have to bleed out both ports or just the far one?
Last post Oct 04, 2005, 12:45:11 PM
by germ
Last post Jun 10, 2006, 01:47:46 PM
by Rob_O
Last post Feb 12, 2009, 12:30:54 PM
by SolidAxle
Last post Jan 29, 2010, 09:15:40 PM
by Jakesteads
Last post Sep 19, 2014, 05:44:30 PM
by beefyjw
