Author Topic: More 3.0 issues! Blowin fuses, don't know why  (Read 1279 times)
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« on: Oct 29, 2006, 01:57:25 PM »
This has happened two weekends in a row now, and I really need to solve the issue, and I'm not sure where to start.
Problem:  When I get on the freeway, and drive for about 10-20 minutes, I blow my EFI fuse in the fuse block on the pass. side fender.  I can put in another fuse, and get abut 5 minutes more down the road, then it blows again.  3rd time, I can put in a fuse, and it'll blow before I even start the truck.  Then, after letting it sit and cool down for a while, I can put in a new fuse, and it'll start right up and run again.  I haven't hadf the problem in town yet, only on the freeway.  I just checked my EFI relay, my AFM and my fuel pump as per the FSMs, and everything is within specs. (except for the fuel pump pressure, I don't have a way to gauge that. )  I do have a check engine code, my O2 sensor is bad according to the code.
Any ideas?  the motor is a 3.0 v6
              -Ronald Reagan
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: More 3.0 issues! Blowin fuses, don't know why
« Reply #1 on: Oct 29, 2006, 02:34:12 PM »
Problem: the motor is a 3.0 v6
You answered your own ?   :rofl2:
I'd fix all the O2 sensors and start fresh.  That could be making it to draw more current, and causing it to blow fuses!  What type of code reader ya using?  My mech has a snap-on that's awesome!  It will give ya very detailed read out of everything, I mean EVERYTHING!!  So, hopefully ya get it figured out!
BLACKDOG [OP]
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #2 on: Oct 29, 2006, 04:41:14 PM »
[/quote]
good idea :thumbs: I'm just running off the code sequence that I get by the shadetree mechanic way
              -Ronald Reagan
Last post May 20, 2003, 12:15:48 PM
by dan_b
Last post Mar 29, 2005, 06:18:15 PM
by MUDDONKEY
Last post Nov 01, 2006, 07:56:30 AM
by Willy Mammoth
Last post May 21, 2010, 07:40:51 PM
by Snowtoy
Last post Dec 21, 2022, 03:44:08 AM
by Gnarly4X
