Author Topic: Charging syetem no workie.  (Read 1511 times)
yotadork83
  • Turtle Points: 18
  • Male Posts: 705
  • Member since Mar '06
  • ninja turtules rule!!
« on: Oct 24, 2006, 10:34:23 AM »
I got a 79 4x4 long bed for free and the original alternator and voltage regulator were allready missing.
last night i bought a new alternator and voltage regulator for it and i cant get it to charge. in my 81 manual it says that there is a diconect relay that might go bad and i am thinking that this is the problem considering that the charge light doesent work any more and in the manual it says that if the light doesnt work to check this relay. i couldent find were it is located at or if the 79's had one of these or not. also there is a single yellow wire with a female barb conector that comes off of the voltage regulator and there is nothing to conect it to besides another yellow wire with a female barb conector, not sure is some thing goes in between or not.
i will post a pic tonight if somebody that has a 79 could take a pic of there VR so i could see if there needs to be some thing in between the two yellow wires or not that would be awsome.
and if anone knows if the disconect relay realy exist or not that would be awsome also.
  thanks in advance ray
yotas 4 life homie!
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Charging syetem no workie.
« Reply #1 on: Oct 24, 2006, 11:13:33 AM »
its not charging cause the "stimulater" wire isnt getting juice from the ignition  i think this  is the sideways plug  on the 3 pronge  plug
2  go | |    and this one goes --
yotadork83 [OP]
  • Turtle Points: 18
  • Male Posts: 705
« Reply #2 on: Oct 24, 2006, 11:15:49 AM »
are you talking about on the alternator it's self or the relay.
yotas 4 life homie!
« Reply #3 on: Oct 24, 2006, 11:46:40 AM »
on the alt
yotadork83 [OP]
  • Turtle Points: 18
  • Male Posts: 705
« Reply #4 on: Oct 24, 2006, 12:27:45 PM »
so it is the od ball of the three wire's i am going to check it on my lunch break.
yotas 4 life homie!
yotadork83 [OP]
  • Turtle Points: 18
  • Male Posts: 705
« Reply #5 on: Oct 24, 2006, 02:21:08 PM »
all right that isnt the problem diffently got power down there. here is a pic of the two wire's i was talking about.
yotas 4 life homie!
« Reply #6 on: Oct 24, 2006, 05:32:27 PM »
i have a condenser   on that one
Last post Sep 07, 2012, 12:09:44 PM
by 907yota
Last post Apr 19, 2004, 01:33:54 AM
by mr4x42u
Last post Mar 27, 2005, 08:00:22 PM
by 89 toy
Last post Oct 06, 2005, 04:41:41 AM
by Boomez
Last post Nov 12, 2009, 06:59:13 PM
by Dooner
