Author Topic: valve clearance.  (Read 2124 times)
CaliZuki
  • Turtle Points: 57
  • Male Posts: 85
  • Member since Mar '06
valve clearance.
« on: Oct 13, 2006, 10:54:51 AM »
anyone know what the valve clearance is on a 82 22r? i cant seam to find the clearance. i did a search and didnt find anything. is it set to zero lash? or is it done with a fealer guage? if it with the guage what size do i use? thanks
madhunt
  • Turtle Points: 52
  • Male Posts: 490
  • Member since Apr '06
Re: valve clearance.
« Reply #1 on: Oct 13, 2006, 11:10:08 AM »
intake should be .008 exhaust is .012 I would set it a little loose for smog and right on for driving
HIGH AND TIGHT OFFROAD
CaliZuki [OP]
  • Turtle Points: 57
  • Male Posts: 85
« Reply #2 on: Oct 13, 2006, 12:23:56 PM »
thank you so much.  this should fix my problem right up.
CaliZuki [OP]
  • Turtle Points: 57
  • Male Posts: 85
« Reply #3 on: Oct 13, 2006, 03:53:15 PM »
well my truck runs better now. but i still have a little miss. need to get me a compresion tester for my next test. i hope i dont have low compresion. but if i do that mean my new engine swap gets to happen a lil early.
8D3TOY
  • Member since May '05
« Reply #4 on: Oct 13, 2006, 04:17:55 PM »
I have been messing with this for a while now 79Coyotefrg was helpin me a bit and set his at .007 &.010 I used these #'s and my motor ran great nice and quiet but after about 100 miles my ticking is back.  Use a blade style feeler gauge.  Thats what I am doing just milking it till I have enough to build another motor, good luck.
madhunt
  • Turtle Points: 52
  • Male Posts: 490
« Reply #5 on: Oct 13, 2006, 04:37:26 PM »
after adjusting the valve make sure when you tighten down the lock nut it didn't move the adjuster screw , make the lock nut very tight also they ave been known to back off. and adjust the valve with a warm motor not cold!!!
CaliZuki [OP]
  • Turtle Points: 57
  • Male Posts: 85
« Reply #6 on: Oct 14, 2006, 11:40:08 PM »
my valves where way to tight. couldnt even get the fealer gauge under them.  now there all adjusted and the engine runs alot better. but i still have a rough idle. and 2 missfires. i have done a full tune up on it. plugs, wires. cap , all the good stuff. i think im just going to run it for awhile. and just build me up a new one.
Last post Jan 25, 2007, 10:19:42 PM
by Mnmstoy
Last post Nov 01, 2010, 09:13:59 AM
by ninja turtle
Last post Jan 25, 2011, 01:09:04 PM
by jrock
Last post Sep 25, 2013, 04:55:36 AM
by jssgbsn
Last post Apr 06, 2017, 03:43:32 AM
by H8PVMNT
