valve clearance.
Started by CaliZuki, October 13, 2006, 10:54:51 AM
CaliZuki
anyone know what the valve clearance is on a 82 22r? i cant seam to find the clearance. i did a search and didnt find anything. is it set to zero lash? or is it done with a fealer guage? if it with the guage what size do i use? thanks
madhunt
intake should be .008 exhaust is .012 I would set it a little loose for smog and right on for driving
HIGH AND TIGHT OFFROAD
CaliZuki
thank you so much.  this should fix my problem right up.
CaliZuki
well my truck runs better now. but i still have a little miss. need to get me a compresion tester for my next test. i hope i dont have low compresion. but if i do that mean my new engine swap gets to happen a lil early.
8D3TOY
I have been messing with this for a while now 79Coyotefrg was helpin me a bit and set his at .007 &.010 I used these #'s and my motor ran great nice and quiet but after about 100 miles my ticking is back.  Use a blade style feeler gauge.  Thats what I am doing just milking it till I have enough to build another motor, good luck.
madhunt
after adjusting the valve make sure when you tighten down the lock nut it didn't move the adjuster screw , make the lock nut very tight also they ave been known to back off. and adjust the valve with a warm motor not cold!!!
CaliZuki
my valves where way to tight. couldnt even get the fealer gauge under them.  now there all adjusted and the engine runs alot better. but i still have a rough idle. and 2 missfires. i have done a full tune up on it. plugs, wires. cap , all the good stuff. i think im just going to run it for awhile. and just build me up a new one.
