I am looking to swap in an automatic when I do the 22re motor in my '82 I haven't done the gears yet so I should go with 5.29's?I will be runing daul cases.How slugish will it be on the street?I usually just drive it around town for fun, no real freeway miles.
Just bought a 88 4 runner with a auto tranny....First auto I've had..Are they worth anything? The truck runs great and shifts good but I'm thinking about converting it to 5 speed. Is there several different auto trannys and If so can you point me in the direction of figuring out what it is...I know It has 4.30 gear if that helps.
dual cases and a A340F dont work,
from what i gathered they were going to, but tooling and the like was too much $$$$. what you want is an auto from a 4wd truck or 4runner, then use the inchworm adaptor to run dual cases. that is the easiest and cheapest way to go right now. the article i posted was from a few years back before any of the inchworm or gearslug invented their adaptors.
Started by RABIDYOTA Engine
Started by 85yotapolo Engine
Started by lilchoppchopp Toyota Pickup/4Runner Tech 1979-95
Started by BadnewsBob Project Research and Build-Ups
Started by idahank Transmission/Clutch
