I want an automatic trans.......?
Started by BadnewsBob, October 24, 2011, 05:54:08 PM
BadnewsBob
I have my buggie to build and I want an auto in it, What do you think is the best route......
1) stay with the 22re I have and find a auto trans for it.   ( can I get dual gear drive Tcases for it?)
2) 22re and a chevy transmission?
3) 3.4 V6 and what? trans......can they be dual cased.....and right hand drop?
I am gonna be running two toy front axles so I can have rear steer.
4) 4.3 chevy, turbo 350, dual toy T cases.
It's a bare frame so the option list is long......
I have 22re stuff and know where to get a complete auto trans/Tcase for it.
4.3 chevy and trans is easy, many of those around here fairly cheap.
I know nothing of the 3.4 toy at all but I do know where a supercharged one can be had.
six of one half a dozen of the other....to many options makes this hard. :dunno:
AE2 USN ret
No matter where ya go..... there ya are.
Hillbilly Offroad
84 xtra cab on 63" chevies and RUF 35" KM2s 22R 5 speed DTC 5.29s Locked front and rear.
R.DesJardin
Quote from: BadnewsBob on October 24, 2011, 05:54:08 PM
YES
A340/AW4 hybrid bolts to Atlas
Good option
I have 22re stuff and know where to get a complete auto trans/Tcase for it. Make sure you get an A340F, I wouldn't mess with an A340H.
I know nothing of the 3.4 toy at all but I do know where a supercharged one can be had. Good motors and easy to connect duals to now.
R.DesJardin
BadnewsBob
Looks like I really need to research the A340F, But I am kinda leaning towards the 4.3 chevy option....Around here you need horse power and wheel speed ,crawling don't always cut it.
AE2 USN ret
Hillbilly Offroad
Rocksnail
I vote for #4 cuz i have that set up. 4,3 th350 duels with 4.7 rear is crazy with this set up.  Most the time i dont even need the 4.7 but its so nice to have when i want it. Run a good cooler with fan for the tranny. I dont even use the stock cooler in the radiator. I just run a external with a fan and it hasnt even got close to hot yet.
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
A friend of mine has a 4.3 with a th400 dual ultimates and it is an awesome rig. If I had a bland canvas that is exactly what I'd do.
Toymin8r
I am starting to love my automatic but I don't think it's a good option behind a 22re.  There's just too much power loss.  I like the 3.4 idea but the Chevy 4.3 is probably going to be cheaper because there are tons of them and plenty of aftermarket support.
freds40
You can dual case any of those options. My vote is either the 3.4 or the 4.3. I wouldn't run 4.7s behind either, just 2 stock cases. Both have enough grunt to make the torque convertor work for you and add more crawlability (is that a word) but also allow you to spin up the motor for a bit more wheel speed in each gear.
"between projects"
BadnewsBob
I have two stock cases, so a double kit and a chevy to toy adapter and the 4.3 is looking like the better choice.   I like toyota running gear but $$$$ signs play a big part in my builds chevy parts are way cheaper and easier to come up with.
AE2 USN ret
Hillbilly Offroad
R.DesJardin
Quote from: BadnewsBob on October 26, 2011, 12:44:23 PM
Sounds good let's see the build! An EFI 4.3 I hope?
R.DesJardin
freds40
I really like the 3.4 but the 4.3 is definitely more plentiful and therefore the cheaper route and makes the choice between the 2 a bit less difficult.  :ha_ha:
"between projects"
BadnewsBob
It will be EFI for sure, Don't know what type yet depends on what I can come with for the right dollars.
AE2 USN ret
Hillbilly Offroad
bigarms23
i vote 4.3 its was an inexpensive swap but im running a 92 cpi 4.3
