but your losing a lot of power and gas mileage.
Not to hi-jack, but is there an easy way to tell if it's bad? That sounds like my truck, has absolutely no power. Might have to invest in one.
you can test it
Like at a parts store?
unplug it, if it doesnt change then yours is bad
Now tell me if you think this is tps problems. Sometimes mine truck will fire up and then stall when i start it for the first time in a couple hours. I have to give it some gas as it starts to keep from stalling it. When i get to higher alttitude like the rubicon its worse and the idle is really weak and stalls easily. Also my mpg is 13 on a new 22re with 36" iroks. Do i need a new one?
ok so i put in a working tps out of another truck of the same year and model. it screwed up the idle. it did that thing where it surges bad and sitting in one place out of gear would not rev up past 2000 rpm. i tried to mess with the adjustment on it and no matter where it was it wouldnt run anywhere near right. i dont really know what to do ill probably just leave it off and continue to run without it. any ideas on what my problem is?
Started by 84runner Parts For Sale
Started by supermat General 4WD Discussion
Started by Misfit4Runner Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by REG535 Toyota Pickup/4Runner Tech 1979-95
Started by abnormaltoy Chit Chat Camp
