MY 1st gen
Started by rocktoy83, July 09, 2006, 08:15:47 PM
rednk1980
The dash looks awsome i like how clean i looks
854RUN
#31
Dash look good man  :biggthumpup:. Did your stock speedo cable work ok for your autometer speedometer? How did you get the speedometer cable to stay on the threads? i was going to use a hose clamp  :dunno: o and toys have a triangular cable end and the auto has a square  :headscratch: I bought autometer pro-comp gauges but did not put them in yet, need to figure out what to do with the speedo.
"toys have a triangular cable end" Never mind its been some time since i have looked at the cable end, just looked at it and its square  :hammer:  :_oops:
-JOSH-
CrazyYota
your truck looks sweet!! :beerchug:
Hottrod81
Nice looking project.  What kind of bling besides the 30 splines do you have in the drivetrain?
rocktoy83
Quote from: 854RUN on September 18, 2006, 10:44:10 AM
The stock speedometer cable is square so is the auto meter one,but the threads are not the same so i still have to fined a way to make it stay.will post up when i get it all dun  :thumbs:
rocktoy83
Quote from: Hottrod81 on September 18, 2006, 03:48:42 PM
Well as for my drivetrain it has 5.29 gears, :turtle: dual T-case with 2.28 stock gears and lock front and rear  :beerchug:
AZman
This is a sweet build up. I see on you pics it says AZUSA do you like in arizona?
AaronB
cheap sunglasses
Lookin very nice. I especially like the dash. Maybe someday I will take the plunge and pull my broken plastic out and put in something nice and simple like youve done.
'82 on 35's, not much else.
rocktoy83
Than ex for all the reapplies on how the dash look :beerchug: .I tried to keep it as simple as possible,but i still have to add sum switch's and the radio.Today i sat in the truck and all the glare of the aluminum dus not let you see out the wind sheled.If anybody has sum ideas or suggestions let me no on how to fix this problem,THANKS  :thumbs:
rockcrawlinredneck
Not to sound like captain obvious (sp) but you could paint it?
Kevin
rocktoy83
Quote from: rockcrawlinredneck on September 19, 2006, 06:40:32 PM
Kevin
Yes i was thinking of painting it black :dunno: ,just wonted to get more opinions on what to do  :thumbs:
rednk1980
Shamb
I like that dash, simple but it looks nice. Are you welding that aluminum diamond plate or.. ?
looks good!  I'm thinking about doing a custom dash in mine because its hacked.
cheap sunglasses
rednk1980
Hey, I'm building an exo cage to go off of my flat bet do you by chance have any diagrams on how u built yours so i could sort of get an idea on how to do mine   :think:
AZman
Good looking build. I really like the dash. Was the wireing hard?
Keep the pics coming.
sgt.majorcrash
I have a question about the seats do you feel that you have enough room in the cab with the prp's seats. I am 6' at 210 and I am a little worried about space in the cab with a new set of the DD seats from prp. also what did you do for mounting the seats did they fit in the stock location or did you fab some mounting hardware. And by the way i read the buildup so far and its just kick ass from the get go man. I went out and ripped the old dash from my first gen after i saw your idea.
rocktoy83
The seats fit good for me  8)  , but i am 5'7 there is still a bit of room.I fabbed up sum stuff so i can use the stock bracits, i jut mad them a bit longer by using sum angel iron.I will see if i can get sum pics up for you  :thumbs:
sgt.majorcrash
Are the seats in a permanent location or are they on an adjustable slide.
cheap sunglasses
How did the autometer gauges hook up to the toyota senders.. like water temp and oil pressure. What ohm range is the fuel level gauge?
Im going to be doing this on my 82 but it will be with a 22r not the r/e so Im sure there will be some difference.
rocktoy83
Quote from: cheap sunglasses on October 18, 2006, 04:20:18 PM
I have not got to the wiring of the gauges yet, but the water temp and oil pressure cum with there own senders so i think they shooed work fine :think: The fuel level gauge i think is going to be the hardies to get to work, cus of the the ohm :smack: I will let you no how it works out win i get it all dun  :thumbs:
rocktoy83
Today i did not have much time to work on the toy, but i did get one thing dun i sealed the computer with plasti dip to help keep it for getting wet. I hope to get a lot of work in on the toy tomorrow and sum more pics up of all the progress  :thumbs:
cheap sunglasses
Quote from: rocktoy83 on October 21, 2006, 09:50:57 PM
Thanks, Ill stay posted. I might use a fuel cell so that would simplify the fuel level gauge a lot for me.
boggerunner
Quote from: rocktoy83 on September 19, 2006, 02:15:06 PM
i had the same problem with a white dash in my crx, i dont know of a fix for it exept for paintin it a dark color.
looks good, i used the 92 dash in my 79 p/u, it turned out good
rocktoy83
So i got sum more work in on the toy yesterday. I got the new 30 spline longs in with the chromoly hub gears and re built the knuckles.
rocktoy83
#58
I also painted my steering,shocks and my hubs in blue.
cheap sunglasses
