4 inch springs, 2 inch body from 4Crawler, 2 inch engine lift from him as well. Push the gas tank up 2 inches. Custom cross member and a clocked Marlin and you can about flat belly. You will have about 4-5 inches better break over clearance with that set up then you will 5 inch springs and only be 1 inch taller. Also improves cross over oil pan clearance.
