LBC Banks Install
Started by Lady Di, May 21, 2006, 07:57:34 AM
Lady Di
That's what I said yesterday, unless we can test it going up a steep incline and see what it does we won't really know for sure, but we don't have many steep inclines round these parts.
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Willy Mammoth
#31
The small turbo the harder it has to work to build boost, but the heat gained in the process causes the air to be less dense.
A larger compressor section should build boost faster and give more boost without building as much heat.
More without a load and even more with a load.
Lady Di
That sounds good to me :thumbs: Well? Where's the new compressor?
unclejpl4x4
Dose that puppy have a intercooler on it ?     looks like U got room for one ?
Willy Mammoth
Yup, it has a damm big one too. The piping is 3 1/2".  If it wasn't so big I bet it would boost quicker.
unclejpl4x4
ya U need a bigger turbo    2 much volume   for that small turbo.
As for me I would love 2 put bigger piping on the supra  but the price is crazzy for a interclooer kit.
freds40
I know more coin isn't what you're looking to spend but the turbo I'm eyeballing for my 600= hp setup is Edge's new Jammer BB. Supposedly works great for the stock setups, more boost, better power. For mine, should increase spool up and cool me down a bit. From what I've heard so far, it's a pretty slick unit.
"between projects"
Willy Mammoth
Ok, back from another test drive with the wastegate blocked off and it can only build 30 psi. Does feel a little better, but not there yet.
I guess I am going to look for a bigger turbo so the boost comes up quicker and harder. Hope I can get at least 35 to maybe 40 psi.
I also think the Banks sticker on the back is going to get turned upside down. These people are no help and they got payed plenty.
get one of those stickers with the little boy  peeing  and stick it next to the Banks sticker
did you find a hill??   tow your service truck and see how it does
Willy Mammoth
I wonder if advancing the injection pump would do any good. I know it did wonders for the Mammoth. If I put it on the timing mark it won't rev up under load so it takes a long time to get up to speed if it even will.
yep,  try it 1 tooth
i know on a mack it makes ALOT of difference
Willy Mammoth
Quote from: 79Coyotefrg on June 04, 2006, 11:03:00 AM
yep,  try it 1 tooth
Doesn't it have a slotted bracket so it can be adjusted?
some have shims  under the torque rod
it does have  like  torque rods  on each side ,  air bag suspension isnt it
i would go with shims,  i dont think it would have a slotted hole  ,too easy to get out of wack,
if it changes lanes when you let go of the wheel i would say a lower arm bushing is totally gone
im guessing it has a LARGE version of a 4 link
Willy Mammoth
 :dunno:
What are you  :blah: about any way  :yupyup:  :psss:
:smack:  the LBC rear suspension :dunno:
Willy Mammoth
:offtopic: :idiot:
Ok, I will run with it. The wheelbase is off by 1". The left side longer so that would mean it will wander to the short side (right).
Now to see if there is anything worn out or if it was made that way. I am leaning toward it being made that way judging by the rest of the their work.
:thud:      if it was made that way you have to fix their  mess up
take a pic of the rear suspension from under the truck
Willy Mammoth
I will have to start with the rear and make sure it is square and straight inline with the frame before I play with the front.
ok, let me know what ya find
Willy Mammoth
Hard to see, but I am sure you get the idea. There is a big square frame attached to the axle and an air bag in each corner. It is four link with a panhard bar.
is the link  on the left have a busted bushing??
Willy Mammoth
Don't look like anything is worn that bad, but there seems to be some rust staining coming from the bushing areas.
Quote from: Willy Mammoth on June 04, 2006, 07:23:49 PM
that means the rubber part is worn  and its riding on the metal  :headscratch:   is the bushing replaceable ?  or is it like a peterbuilt ,have to replace the entire link
Willy Mammoth
This stuff is all home made crap. I should be able to rebuild it if needed, I just don't want to need to.
