Mine did the same thing, but then finally it just wouldn't go into gear. It was because the clutch master cylinder was leaking and wasn't disengaging the clutch all of the way. I just changed it and it works fine now. You might want to check that out.
That would be my guess to if it happening only at a stand still in gear. The clutch is simply not disengaging all they way.PZ
i did the compression test today my #1 cylinder had no compression whatsoever the rest did, so what do you guys think is it a valve or is it my piston rings? thanks for your help
Started by crash General 4WD Discussion
Started by booger1 General 4WD Discussion
Started by Crash_AF Toyota Pickup/4Runner Tech 1979-95
Started by motodude Toyota Pickup/4Runner Tech 1979-95
Started by MidgetMike Engine
