22re problem
Started by booger1, August 21, 2005, 06:16:31 PM
booger1
on my 93 pickup it has been acting funny ( I think someone has been messing with it).  it used to run real good, but then it would act like it was running out of gas and die, then it would start right back up.  I poured some heet into it, thinking something was in the gas tank, and that cleared it up for a few days.  now it run perfect, but it has problems starting.  what could be wrong.  the engine is turning over perfectly, but I have to play with it a little to start, and it is kind of embarrasing when it does not want to start. :sad2:  :rivers:
nick
93 pickup,  sas'd, 36in tsl's, tundra front clip, taco bed, kenwood, apexi intake,  7mgte.
toyoder
check your fuel pump and fuel filter.
zuk tube buggy
22re powered
jeff_aitch
does the engine light come on?
germ
I would also check your plugs and wires to make sure that you're getting a good spark.  You may want to check the distributor for cracks or excessive moisture.
Good luck, let us know what you find out.
Erik :usa:
